Arducam Pan Tilt Camera Bundle for Nvidia Jetson Xavier NX/Nano, 2 Two-DOF Platforms with 8MP IMX219 Cameras, with PTZ Control Board
Arducam IMX219 Wide Angle Camera Module for NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
Arducam IMX219 Wide Angle IR Sensitive (NoIR) Camera Module for NVIDIA Jetson Board
B0193
was $39.99 Special Price $27.99
This Arducam IMX219 NoIR camera module is mainly designed for NVIDIA® Jetson Board and also can be used on other hardware like ARM, DSP, FPGA, etc. The highlight of this camera is its wide field of view.
★KERNEL CAMERA DRIVER USED
Image Sensor IMX219
Still Resolution 8 Megapixels
3280x2464@21fps, 3280x1848@28fps, 1920x1080@30fps, 1640x1232@30fps, 1280x720@60fps
Pixel Size 1.12 µm x 1.12 µm
Optical Size 1/4"
IR Sensitivity without IR-cut filter, sensitive to IR light
Focal Length 1.3mm
F.NO F2.0
Field of View(FOV) 155°(H)×115°(V)×175°(D)
Electrical & Mechanical
Camera Board Size 25 x 24mm
Peaking Current 300mA
  • 1pcs Arducam IMX219 Wide Angle NoIR Camera Module for NVIDIA Jetson Board
  • 1pcs 15cm 22-22pin FPC cable
  • 1pcs 15cm 15-22pin FPC cable
    Used on Jetson
    IMX219 – 8MP Camera
    3D drawing.step
    2 comments
