Arducam 12MP 477P Pan Tilt Zoom(PTZ) Camera for Raspberry Pi 4/3B+/3 and for NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX, IR-Cut Switchable Camera
Arducam 5MP 1080p Pan Tilt Zoom PTZ Camera for Raspberry Pi 5/4/3B+/3
Arducam 8MP Pan Tilt Zoom PTZ Camera for Raspberry Pi 4/3B+/3 and NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
B01678MP
  • Real PTZ with servos for directional control and a varifocal lens for optical zoom now comes to the Raspberry Pi and Jetson Board
  • Switchable IR Cut: Through software to achieve your day/night vision
  • Make full use of the CSI connector now that a single camera can be used to monitor more places
  • Software Control: Autofocus control, pan/tilt/zoom keyboard control
  • Based on Sony 8MP IMX219 HD Sensor. Max Resolution: 3280 (H) × 2464 (V)
  • PTZ Controller Board Connector Part Number: S6B-XH-A-1
$94.99
PTZ is an abbreviation for pan, tilt, and zoom and reflects the movement options of the camera, and a pan–tilt–zoom camera (PTZ camera) is a camera that is capable of remote directional and zoom control. A PTZ camera is not a still camera. Instead, it could move the camera and the lens, and that means a single camera can be used to monitor places that should be covered by multiple ones. You can save a lot of cost and time in purchasing and deploying the camera if a PTZ camera can handle the job. With its moveable lens, you will also be able to zoom the camera to see a specific area that you are interested in. To conclude, it’s “do more with less.”
★KERNEL CAMERA DRIVER USED
  • IoT cameras
  • Robot cameras
  • Sun Tracker
  • Wildlife cameras
  • Other security and surveillance projects, etc,
Image Sensor Sony IMX219
Optical Size 1/4”
Active Pixels 8MP 3280(H)x2464(V)
Frame Rates 1080p47, 1640 × 1232p41 and 640 × 480p206
NVIDIA Jetson Orin NX/Orin Nano/AGX Orin:
3280x2464@21fps, 3280x1848@28fps, 1920x1080@30fps, 1640x1232@30fps, 1280x720@60fps
Focal Length 3.2-11.1mm±5%
F.NO W:1.6-T:3.3±5%
Focus Type Front group: focus Back group: Zoom
IR Sensitivity Optional with additional Motorized IR-Cut filter
M.O.D 0.8M
Dimension  36mm x 36mm
Pan and Tilt Range 0-180°
Zoom Range (Wide => Tele) 2317 steps 0.00396mm/step
Focus Range(Near => Far) 3009 steps 0.0047mm/step
  • 1 x Arducam PTZ Pan Tilt Zoom Lens, assembled with a 8MP IR-CUT switchable camera board
  • 1 x Controller Board
  • 1 x 15-15Pin FPC Cable (11.8 in/30 cm)
  • 1 x 15-22Pin FPC Cable (11.8 in/30 cm)
  • 1 x XH2.54 Jumper wire with 6Pin Female Connector (11.8 in/30 cm)
ptz-pan-tilt-zoon-camera-on-raspberry-pi-arducam-blog-thumbnail
Pan/Tilt/Zoom (PTZ) Camera Is Finally Coming to The Raspberry Pi Thanks to Arducam
We all know that there is a CSI connector on the Raspberry Pi to facilitate the connections of a small camera to the processor, but how should we facilitate the small camera itself? As a professional camera manufacturer and solution provider, Arducam has been obsessed with this question for the last 6 years, and came […]
11 comments
Selection Guide
Edit
B0152 8MP M12 NOIR 8MP RGB rolling shutter 36mm&l
