Arducam IMX477 12MP PTZ Camera for Raspberry Pi 4/3B+/3 and Jetson Board, IR-Cut Switchable Camera with Metal Base and 2 Digital Servos
Arducam 12MP 477P Pan Tilt Zoom(PTZ) Camera for Raspberry Pi 4/3B+/3 and for NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX, IR-Cut Switchable Camera
Arducam High Quality IR-CUT Camera for NVIDIA® Jetson Orin Nano/Orin NX, 12.3MP 1/2.3 Inch 477P HQ Camera Module with 6mm CS Lens
B0274
  • Day/Night Camera – IR Cut filter switched in and out automatically. A NoIR camera that keeps videos and images from washed out or looking pink yet still offers a decent night vision
  • Get Clearer Images: This camera adopts 1/2.3″ 12.3 Megapixel IMX477 sensor for sharp image, max. still resolution 4056(H) x 3040(V).
  • Less Hassle: No more wasting time looking for the CS lens and camera case. A 1/2.3″ 6mm focal length CS lens is included, and the 3D file of the camera can be downloaded to print your case. Also, you can search for B0241 to get the camera bundle with the metal enclosure.
  • More Lanes: The Arducam high quality camera module has a 4-lane MIPI CSI-2 interface, more than the official one, makes it possible to get more data through.
  • Note: For the new version(R32 4.4), please refer to the following link: https://github.com/ArduCAM/MIPI_Camera/releases/tag/v0.0.2
was $79.99 Special Price $64.99
This Arducam module uses the same 12MP IMX477 image sensor as the Raspberry Pi High Quality Camera, but offers a mechanical IR cut-off filter switched automatically based on light condition. The official RPi HQ camera is not sensitive to infrared, and there won’t be a NoIR version. On the contrary, this Arducam camera module not only offers sensitivity to infrared but also keeps the natural feeling during daylight. It’s fully compatible with Jetson Board with a camera connector.
KERNEL CAMERA DRIVER USED
SUPPORTED PLATFORM DISCLAIMER
ADDITIONAL ACCESSORY INSTRUCTIONS
Video Modes
NVIDIA Jetson Orin NX/Orin Nano/AGX Orin:
Pixel Size 1.55 µm x 1.55 µm
Optical Size 1/2.3"
IR Sensitivity Switch the IR cut filter on/off automatically
Focal Length 6mm
F.NO F1.2
Field of View(FOV) 65°(H)
Lens Mount CS-Mount
MOD 0.2m
Back Focal Length 7.53mm
Lens Dimension Φ30×31mm
Electrical & Mechanical
Camera Board Size 38 × 38mm
Hole Pitch Compatible with 29mm, 30mm, 34mm
Peaking Current 300mA
Lens Options
CS-Mount Lens
SKU LN051 LN050 LN038 LN039 LN040 LN041 LN029
Part No
CS17320M12
CS2316ZM02
CS2308ZM05
CS2008ZM05A
CS1812ZM03
CS2325ZM01
CS1806ZM06
Optical Format 1/1.7″ 1/2.3' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3'' 1/2.3''
EFL(mm) 3.2 16.00  8.00 8.00 12.00 25.00 6.00
BFL(mm) 5.94 7.53 6.50 7.53 7.53 8.03 8.03
F/NO 2.0 1.2  1.4 1.2 1.6 1.2 1.4
HFOV on 1/2.3‘’ Cam 120° 24° 50° 50° 30° 14° 65°
MOD 0.30m 0.20m  0.30m 0.20m 0.20m 0.20m 0.30m
Size(mm)
28×30 30×29 28×23 30×29.5 30×29 28×29 28×28.5
NOTE: The CS-Mount Lens kit for the HQ Camera module, please check LK004, 5 lenses are included.
C-Mount Lens
SKU LN054 LN052 LN046 LN042 LN043 LN044 LN045 LN047
Part No
C1550ZM01
C1535ZM02
C1016ZM02
C1705ZM07
C1508ZM04
C1512ZM03
C1516ZM02
C1535ZM01
Optical Format 2/3″  2/3″ 1'' 1/1.7" 2/3" 2/3" 2/3"  2/3"
EFL(mm) 50.00  35.00 16.00 5.00 8.00 12.00 16.00 35.00
BFL(mm) 17.53  17.53 17.53 17.53 17.53 17.53 17.53 17.53
F/NO 1.8-16 1.6-16 1.4-1.6 1-1.6 1.6-16 1.6-16 1.6-16 1.7-16
HFOV on 1/2.3‘’ Cam 18° 24° 65° 44° 31° 24° 10°
MOD 0.50m  0.30m 0.20m 0.15m 0.15m 0.20m 0.20m 0.20m
Size(mm)
34×40.5 50×35.5 39×50 39×41.5 39×41 34×41.5 33×36.5 35×30
C-Mount zoom Lens
