[Discontinued] Arducam 12MP MINI IMX477 Synchronized Stereo Camera Bundle Kit for Jetson Nano and Xavier NX
[Discontinued] Arducam 2MP Global Shutter OG02B10 Color Camera Modules with M12 lens for Raspberry Pi
[Discontinued] Arducam 5MP Wide Angle USB Camera for Computer, 1/4" CMOS OV5648 Mini UVC USB2.0 Video Webcam Without Microphone, with 3.3ft/1m Cable
UB0233
Discontinued, check alternative item B0454.
  • Ultra HD Resolution: This camera adopts the 5MP OV5648 Color COMS sensor for sharp images and accurate color reproduction.
  • Wide Angle: Assembled with a 90-degree horizontal view angle M12 lens with IR filter, which provides a much wider Field of View compared to other lenses.
  • Frame Rates: MJPG 15fps@2592 x 1944/2048 x 1536; 30fps@1080P/720P/1024 x 768/800 x 600; YUY2 5fps@720P/1080P; 10fps@1024 x 768; 15fps@800 x 600.
  • Plug&Play: UVC-compliant, just connect the camera to PC computer, laptop, Android device or Raspberry Pi with the USB cable without extra drivers to be installed.
  • Applications: Highly recommended for the video surveillance system, live streaming, videoconference, dashcam, and other vision applications.
$39.99
Product description
Arducam UB0233 is a 5MP, based on the 1/4" OV5648 image sensor, UVC compliant, wide angle USB 2.0 camera.
Ultra HD resolution meets your request of higher quality video still pictures resolution.
Live streaming
Videoconference
Monitoring 3D printer
Dashcam
Specs
- Sensor: 1/4” OV5648
- Resolution: 5MP 2592 x 1944
- Data Format: MJPG 15fps@2592 x 1944/2048 x 1536; 30fps@1080P/720P/1024 x 768/800 x 600; YUY2 5fps@720P/1080P; 10fps@1024 x 768; 15fps@800 x 600.
- Field of View (FOV):90 degree (H)
- Lens Mount: M12
- IR Sensitivity: Integral 650nm IR filter, visible light only
- Adjustable parameter: Contrast/ Saturation/ Exposure/ White balance
- System Compatibility: Win7/8/10, Linux, Mac, and OS with UVC driver
Power
- Working Current: MAX 250mA
Physical
- Dimension: 32mmx32mm
- Hole Pitch: 28x28mm
- Cable Length: 3.3ft (1M)
Lens Options
LN001
LN002
LN003
LN004
LN005
LN006
LN007
LN008
LN009
LN010
Part No
M2016ZH01
M2508ZH02
M2506ZH04
M25360H06
M27210H08
M40180H10
M25170H12
M25156H14
M30171H16
M32076M20
Optical
Format
1/2.5''
1/2.5''
1/2.5''
1/2.5''
1/2.7''
1/4'
 1/2.5''
1/2.5''
1/3''
1/3.2''
EFL(mm)
16.00
8.00
 6.00
3.60
2.10
1.80
1.70
1.56
1.71
0.76
BFL(mm)
7.10
8.10
 7.30
5.00
6.30
4.90
4.70
4.30
4.71
2.00
Construction
6G+IR
6G+IR
6G+IR
6G+IR
6G+IR
6G+IR
 6G+IR
 6G+IR
5G+IR
2G4P+IR
F/NO
2.0
2.0
 2.0
2.0
2.0
2.4
2.0
2.0
2.2
2.1
HFOV on 1/4‘’ Cam
10°
26°
33°
67°
73°
100°
118°
141°
180°
220°
IR filter
650 IR
filter
650 IR
filter
650 IR
filter
650 IR
filter
650 IR
filter
650 IR
filter
650 IR
filter
650 IR
filter
650 IR
filter
650 IR
filter
MOD
0.3m
0.30m
 0.30m
0.20m
0.30m
0.20m
 0.20m
0.20m
 0.20m
0.20m
Size(mm)
14x16.2
14x16.9
14x17.4
14x16.8
14x15.2
14x14.5
20x18.7
20x17.3
15x19.7
16x13.5
Low Distortion Lens Options
LN011
LN012
LN015
LN013
LN014
Part No
M2504ZH05S
M25360H06S
M40320M06S
M27280M07S
M40210M09S
Optical Format
1/2.5''
1/2.5''
1/2.5''
1/2.5''
1/2.7''
EFL(mm)
4.00
3.60
 3.20
2.80
2.10
BFL(mm)
3.24
2.75
 1.60
2.60
1.19
Construction
2G2P+IR
2G2P+IR
5E+IR
2G2P+IR
2G2P+IR
F/NO
2.8
3.0
 2.0
2.8
2.2
HFOV on 1/4‘’ Cam
45°
55°
65°
70°
80
