Arducam 2MP Global Shutter OV2311 Monochrome Camera Modules for Raspberry Pi
Synchronized Stereo Camera HAT for Raspberry Pi
[Discontinued] 1080P HD Wide Angle WDR USB Camera Module, 2MP 1/2.7" CMOS AR0230 100 Degree Mini UVC USB2.0 Webcam
B0203
Discontinued, check alternative item B0438
  • HD Resolution and WDR: This camera adopts the 2MP AR0230 Color COMS sensor with a 96dB wide dynamic range.
  • Wide Angle: High quality 100 degree wide view angle (diagonal) M12 lens with IR filter.
  • Frame Rates: H.264 25fps@1920 x 1080; MJPG 25fps@1920 x 1080; YUY2 25fps@640 x 360.
  • Plug&Play: UVC-compliant, support Windows XP/7/8/10, Linux, Mac OS and Andriod device with UVC, just connect the camera to PC, laptop or Raspberry Pi with the USB cable without extra drivers to be installed.
  • Applications: this tiny 32mmx32mm camera board can be installed in the most hidden and narrow position for a home video surveillance system, day&night low light vision camera system, dashcam or other machine vision application.
was $78.99 Special Price $59.99
Arducam B0203 is a new member of Arducam’s USB camera family. It’s a 2MP, based on the 1/2.7” AR0230 image sensor, UVC-compliant USB 2.0 camera.
No longer be anxious about installing the driver! The native UVC drivers of Windows, Linux, Mac, and Android shall be compatible with this camera so that it does not require extra drivers to be installed.
This 2MP AR0230 color CMOS sensor produces the camera with a 96dB wide dynamic range, which gives you clearer visual joy when the object is backlighted and is more suitable for home security systems, object tracking, etc.
Features & Specs
  • Sensor: 1/2.7” AR0230
  • Resolution: 2MP 1928H x 1080V
  • Data Format: MJPG/YUY2/H.264
  • Frame Rate: H.264 25fps@1920 x 1080; MJPG 25fps@1920 x 1080; YUY2 25fps@640 x 360.
  • Dynamic Range: Up to 96dB
  • Field of View (FOV): D= 100°
  • Lens Mount: M12
  • Focusing Range: 3.3ft (1M) to infinity
  • Functionality and Compatibility
  • Auto Controlled Features: Saturation, Contrast, Acutance, White balance, Exposure.
  • System Compatibility: Windows, Linux, Mac, and Android with UVC
Power
  • Power Supply: DC 5V
  • Working Current: MAX 300mA
Physical
  • Operating Temp.: -4°F~158°F (-20°C~+70°C).
  • Dimension: 32mmx32mm
  • Cable Length: 3.3ft (1M)
    Lens option
    SKU LN001 LN065 LN002 LN003 LN011 LN012 LN013 LN005 LN055 LN007
    Model No: M2516ZH01 M2512ZH03 M2508ZH02 M2506ZH04 M2504ZH05S M25360H06S M27280M07S M27210H08 M27195H15 M25170H12
    Optical Format 1/2.5'' 1/2.5'' 1/2.5'' 1/2.5'' 1/2.5'' 1/2.5'' 1/2.7'' 1/2.7'' 1/2.7'' 1/2.5''
    EFL(mm) 16 12 8 6 4 3.6 2.8 2.1 1.95 1.7
    BFL(mm) 7.1 6.5 8.1 7.3 3.24 2.75 2.6 6.3 3.8 4.7
    Construction 6G+IR 6G+IR 6G+IR 6G+IR 2G2P+IR 2G2P+IR 2G2P+IR 6G+IR 6G+IR 6G+IR
    F/NO 2.0 2.0 2.0 2.0 2.8 3.0 2.8 2.0 2.0 2.0
    FOV (D/H/V) on 1/2.7‘’ Cam 25/22/12 31/27/15 48/42/25 64/57/34 80/72/45 90/82/52 103/95/63 136/130/101 158/155/136 180/180/180
    FOV (D/H/V) on 1/2.8‘’ Cam 23/20/11 29/25/14 45/40/23 62/55/33 78/70/43 88/80/50 98/90/59 131/125/94 154/150/129 180/180/180
    FOV (D/H/V) on 1/2.9‘’ Cam 20/18/10 26/23/13 43/38/22 60/53/32 76/68/42 86/78/49 93/85/55 127/120/89 149/145/121 180/180/180
    IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter
    MOD 0.3m 0.3m 0.3m 0.3m 0.3m 0.2m 0.3m 0.3m 0.2m 0.2m
    Size(mm) 14 x 16.2 14 x 16.7 14 x 16.9 14 x 17.4 14 x 18.7 14 x 16.3 14 x 15.6 14 x 15.2 17.5 x 19.9 20 x 18.7
    NOTE: The M12 Lens kit for the USB Camera module, please check LK005, 10 lenses are included.
    • 1 × 2MP AR0230 USB 2.0 camera board
