[Discontinued] 1080P HD Wide Angle WDR USB Camera Module, 2MP 1/2.7
[Discontinued] 1080P HD Wide Angle WDR USB Camera Module, 2MP 1/2.7" CMOS AR0230 100 Degree Mini UVC USB2.0 Webcam
[Discontinued] Arducam NoIR IMX219-AF Programmable/Auto Focus IR Sensitive Camera Module for NVIDIA Jetson Nano/Xavier NX
Synchronized Stereo Camera HAT for Raspberry Pi
B0195
  • Note: This Arducam multi-camera sync HAT is no longer sold separately
  • A truly synced stereo camera HAT that lets you use 2 Raspberry Pi cameras on a single CSI port on a single Raspberry Pi camera. Arducam proprietary.
$59.99
Update: This Stereo Camera HAT has been updated into the Arducam Camarray Solution. Now Arducam released a stereo camera HAT for Raspberry Pi which allows you to connect two 5MP OV5647 or two 8MP IMX219 pi cameras to a single standard pi board, and takes images or video at the same time, even more, important they are fully synchronized. The highlight of this stereo camera HAT is that it incorporates Arducam proprietary ArduChip solution, and extends the usage of the single pi camera port, it cheats the Raspberry pi as if only one camera connected. It supports Raspistill command for preview and Raspivid command for video capture/processing with Rpi default camera driver for its 5MP and 8MP cameras. It also supports other Arducam Raspberry Pi cameras and a proprietary camera driver that works up to two 16MP. With the shared oscillator and I2C broadcasting, the two cameras are fully synchronized in the nano-second level. With the latest new coming Pi 4 hardware, Arducam makes more camera applications possible for Raspberry Pi.
  • Support all series Raspberry Pi boards, Pi HAT board style
  • Support 1, 2 and 4 lane MIPI cameras input up-to 800Mbps/lane
  • Support 2 lane MIPI output
  • Support Raspistill (preview) and Raspivid (processing) commands for 5MP/8MP pi cameras with half-resolution combine
  • Support Arducam RPI cameras up to 16MP with proprietary camera driver with full resolution combine
  • Support digital pan in half resolution combine, programmable pan speed control
  • Board size: 65 x 56 mm
  • Weight: 16 g
  • Stereo Vision
  • 360 Camera
  • Advanced Surveillance Camera
NOTE
  • Oscillator sharing requires extra cables, soldering skill needed or please use Arducam bundle kit
  • Contact us for other platform support
synchronized-stereo-pi-camera-hat-dual-blog-thumbnail
58 comments
The Arducam Synchronized Stereo Camera HAT is designed to use two camera modules on a single Raspberry Pi board simultaneously. The model number is B0195. Read more details from the chapters below.
3D drawing.step
