16MP IMX519 Autofocus Synchronized Quad-Camera Kit for Raspberry Pi, NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
Arducam IMX519 PDAF&CDAF Autofocus Camera Module for Raspberry Pi, NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
16MP NoIR Camera Module for Raspberry Pi and Nvidia Jetson Board
B0386
  • No Infrared Filter: perfect for night vision & multispectral applications.
  • Fixed-Focus: great for UAVs, robots, etc.
  • 16 Megapixel: 2 times higher res, half the cost.
  • Sharper Images/videos: Higher quality than the HQ camera.
  • V1/V2 Size: hassle-free upgrades to your existing projects.
  • Field of View(FOV): 66°(H) x 49.5°(V) x 80°(D)
arducam shipping payment 1
$29.99
A NoIR version of the 16MP camera module, with a fixed focus lens.
Without the infrared filter, the IMX519 sensor on this camera is available for applications (night vision/monospectral/multispectral/hyperspectral/etc.) that require the capturing of a much wider spectrum.
We tested this camera with various bandpass filters:
Stills/videos taken under natural daylight will be heavily affected by infrared (see above video), if you don't need IR sensibility, please get the standard 16MP-AF instead.
See the full list of our 16MP cameras >
Sensor Sony IMX519 stacked, back-illuminated sensor 16 megapixels 1.22 µm × 1.22 µm pixel size7.103 mm diagonal (Type 1/2.534)
Output RAW10/8, COMP8
Lens f/1.75; EFL: 4.28
Field of View(FOV) 66°(H) x 49.5°(V) x 80°(D)
IR cut Filter Without IR-cut filter, sensitive to infrared light
Video Modes 1080p@30fps, 720p@60fps
Linux integration V4L2 driver available
Ribbon Cable Length 150mm
Frame Rate (NVIDIA Orin NX) L4t 32.x: 4656×3496@10fps, 3840×2160@21fps, 1920×1080@60fps, 1280×720@120fps
L4t 35.x: 4656×3496@9fps, 3840×2160@17fps, 1920×1080@60fps, 1280×720@120fps
Resolution & Frame Rate on Jetson 4656×3496@10fps, 3840×2160@21fps, 1920×1080@60fps, 1280×720@120fps
The lens on 16MP NoIR is fixed focus.
Raspberry Pi 5 √ √
Packing Including
  • 1 x Arducam 16MP NoIR Camera Module
  • 2 x FPC Cables (15cm 15-22pin & 22-22pin)
Note:
**Get the camera enclosure here.
FaQs
Is this camera compatible with all Raspberry Pi Models?
Yes.
Do I need external IR LEDs if want to use the camera in complete dark?
Yes, IR LEDs are requried if you want to use it for night vision projects.
