64MP Autofocus Synchronized Quad-Camera Kit for Raspberry Pi
Arducam 1MP*4 Quadrascopic Camera Bundle Kit for Raspberry Pi, NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX , Four OV9782 Global Shutter Color Camera Modules and Camarray Camera HAT
16MP IMX519 Autofocus Synchronized Quad-Camera Kit for Raspberry Pi, NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
B0388
  • Multiplexing with ultra high res: 4 x 16mp cameras on 1 Pi.
  • Synchronized: up to 4 cameras capturing at the same time.
  • Autofocus: AF/Manual/Continuous-AF out of the box.
  • Better Control: single/dual/quad channel modes.
  • Highly Compatible: libcamera-ready, works well with most Pi models.
  • Four in One: Combine four cameras into one frame, each camera with a max resolution of 2328(H)x1748(V)
  • For NVIDIA JetsonL4t 35.x Jetpack5.x and above versions , you will need the latest CamArray Kit firmware (no earlier than the 2023.02.03 version) to access it.(otherwise you can only use them on previous JetPack versions).
arducam shipping payment 1
$169.99
A quad-camera kit that allows you to use up to four 16MP autofocus cameras on a standard Raspberry Pi model.
By default, the kit works in a quad-channel mode where all cameras are configured to capture stills/videos at the exact same time.
Supported Modes
Single Channel (no sync):
4 cameras work consecutively where one camera captures after the other. Full res for each.
Dual-Channel (synced):
2 cameras merged into 1 full-res frame, working synchronously. 1/2 res for each.
Quad-Channel (synced):
4 cameras merged into 1 full-res frame, working synchronously. 1/4 res for each.
Demo
Our Camera-Multiplexing Solutions >
See the full list of our 16MP cameras >
Supported Platform Raspberry Pi and NVIDIA Jetson AGX Orin/Orin Nano/Orin NX
Output/CSI-2 Speed x1 CSI-2 2-lane Output Port/1.0 Gbps/Lane
Output Format RAW10
Number of effective pixels 4656(H) × 3496(V) pixels
ISP Support Supported on Raspberry Pi/ Not Supported on NVIDIA Jetson
External Trigger Not Support
Aggregate mode 1/4 Spelling Combine
Frame Rate(On Raspberry Pi) 4656×[email protected], 3840×2160@9fps, 2328×1748@15fps, 1920×1080@30fps, 1280×720@40fps
Frame Rate(on NVIDIA Jetson) L4t 32.x: 4656x3496@5fps, [email protected], 1920x1080@30fps, 1280x720@60fps
L4t 35.x: [email protected], [email protected], 1920x1080@30fps, 1280x720@60fps
Image Sensor IMX519
Active Array Size 4656 × 3496
Optical Format 1/2.53''
Camera Interface 2-lane MIPI CSI-2
IR Sensitive Integral IR-cut filter, Visible Light Only
Camera Board Size 24mm x 25mm
Camarray Hat Size 65mm x 55mm
Field of View 66°(H)x49.5°(V)
Focal Length 4.28mm
Focus Type Autofocus
Focus Distance 10cm~infinity
Packing Including
  • 4 ×16MP Camera Module
  • 1 ×UC-512 Camarray HAT
  • 5 ×30cm 22-22pin Camera Cable
  • 1 ×30cm 15-22pin Camera Cable
  • 1 ×7cm 15-22pin Camera Cable
  • 1 ×8cm 22-22pin Camera Cable
  • 1 ×Screw Pack
  • 1. The four-channel camera adopts the 2×2 synthesis method. The images of cameras 0 and 1 are completely synchronized, the images of cameras 2 and 3 are completely synchronized, and the images of cameras 2/3 are one frame behind the images of cameras 0/1.
  • 2. The resolution of the synthesized image remains unchanged, but the frame rate is halved. This Kit Combines four cameras into one frame, each camera with a resolution of 2328(H)x1748(V).
  • 3. If any camera fails, the composite image can still be output, with the corresponding area of the failed camera being black.
  • 4. Official Commands and ISP are supported on Raspberry Pi Platforms.
  • 5. The four-channel camera is a customized model, requiring HAT to provide a clock. It cannot be removed and is directly connected to the Raspberry Pi.
  • 6. The driver of the kit is mainly developed based on the Raspberry Pi/ Nvidia Jeston official board, and there is no guarantee that the third-party board can be used (Due to the different allocation of hardware resources, it may not be compatible)
  • 7. Due to the hardware limitations of the NVIDIA Jetson platform, this product does not support ISP functionality. If a pre-tuned ISP solution is required, please refer to Arducam xISP series or Arducam TrueSight Series
Raspberry Pi 5 √ √
Raspberry Pi 4B / 3B+ / 3A+ √ √ √
FaQs
Q1: For dual/quad channel mode, does the kit still use the full sensor as input?
A1: When it’s in sync/4-channel mode, it uses ¼ the pixels of each sensor as input. When you switch to single-channel mode, you can get one camera at full resolution!
Q2: For single channel mode, what frame rate can I get and how fast can I capture and swtich betteen cameras?
A2: You can get roughly ~8 frames (full res) per second with single-channel mode, and the HAT we designed has the ability to switch to the next camera after each frame, so in theory, you can switch between cameras every ~125 ms (⅛ s), but, and it’s a huge but, it also depends on how fast you can store that full res image, whether you want the HAT to switch to the next camera after a frame’s captured or stored, which Raspberry Pi model you use, etc.
Q3: Can this work with your cable extension kit?
A3: Yes.
