Most of the DSLR cameras and mobile phone’s cameras are using Rolling Shutter technology including Canon, Nikon, and iPhones, while industry cameras are using Global Shutter technology. Why cameras are so different, let’s take a look at the facts of these two kinds of technology.
Rolling Shutter
Rolling Shutter, usually found in CMOS sensors is a method of capturing an image that does not expose the entire sensor pixels simultaneously, actually it exposures line by line from top to bottom.
Global Shutter
Rather than the rolling shutter camera, the global shutter camera exposures all pixels at the same time. The shutter opens at a certain time then closed, blocking the light enter into the sensor.
Here is a short demonstration of how rolling shutter works in a simplified 10×10 CMOS sensor.
Rolling Shutter vs Global Shutter
Which is better: Rolling Shutter or Global Shutter?
Most of the people think that the rolling shutter is bad. I don’t think so, it is just a kind of technology. There is no better from one than the other if you don’t compare them according to a given application. General speaking rolling shutter is good when low cost, high resolution, and high frame rate is needed, while the global shutter is good for fast moving objects and machine vision applications.
Global Shutter Camera Breakout From ArduCAM
ArduCAM now introduces two global shutter camera headboard based on ON-Semi (used to be Aptina) MT9V022/ MT9V034 (0.3MP) and AR0134/AR0135 (1.2MP). The camera headboard can be used with ARM, DSP, FPGA so similar platforms with parallel camera interfaces.
ArduCAM also provides USB camera shield for seamless integration for these global shutter camera board. Mono and color types are available for both types. The main spec for each sensor list below.
| Part Number | OV7251 | MT9V022/MT9V034 | AR0134/AR0135 |
| Array Size | 640(H) x 480(V) | 752(H) x 480(V) | 1280(H) x 960(V) |
| Optical Format | 1/7.5″ inch | 1/3″ inch | 1/3″ inch |
| Frame Rate | 100fps at full resolution | 60fps at full resolution | 54fps at full resolution
60fps at 720p |
| DAC output | 10-bit | 10-bit | 12-bit |
| Trigger mode | Auto or external trigger input | Auto or external trigger input | Auto or external trigger input |
| Power Consumption | 119mW | 160mW | 400mW |
| Operation Temperature | -30 ~ +70°C | -40 ~ +85°C | -30 ~ +70°C |
| Color | Mono Bayer Pattern | Mono/RGB Bayer Pattern | Mono/RGB Bayer Pattern |
| Pixel Size | 3μm | 6μm | 3.75μm |
| Responsivity | 10.8V/Lux-sec | 4.8V/Lux-sec | 6.1V/lux-sec |
| Dynamic Range | Linear:69.6dB | Linear:60dB, Extended: 100dB | 64dB |
| Lens mount | Stock lens | C/CS or M12.5 mount | C/CS or M12.5 mount |
Support
Send us an email whenever you need any support from us.
