high quality imx477 solutions from arducam
12MP High Quality Sony Exmor RS IMX477 interfaced with Raspberry Pi, Jetson Nano, or Arducam USB Camera Shield, with customizable optical performance.
Cable Extension
Camera Case & Housing
/ Camera Modules /
Arducam 12MP IMX477 High Quality Camera Module, Basic Model, 6mm CS-Lens
Same, but different.
Same IMX477 image sensor adopted as the Raspberry Pi High Quality Camera, but way more customizable with Arducam accessories and drivers.
Arducam 12MP IMX477 High Quality Camera Module, Metal Case, CSI Extension over HDMI
Real High quality, from the inside out.
When the inside gets serious, the outside follows. Industrial level metal housing with a standard tripod mount and robust HDMI adapter to extend the connection.
Arducam 12MP IMX477 High Quality Camera Module, CS-Mount, Switchable Mechanical IR filter
You want IR sensitivity, we give you IR flexibility.
A CS-Mount IMX477 Camera Module – but NoIR or not? Thanks to the mechanical filter, the decision is yours.
Arducam 12MP IMX477 High Quality Camera Module, Motorized Focus or Software Autofocus
IMX477 made versatile as well.
Voice Coil Motor (VCM) inside to focus the lens. What you’ve liked about our V1&V2 Motorized focus Pi cam mods, now all available on the IMX477.
Arducam 12MP IMX477 High Quality Camera Module, M12 Lens, Compact V2-Size Form Factor
Compact, light-weight, and yet high quality.
Could be a smooth upgrade to drop-in replace your original V1 or V2 camera setups. Also suitable for applications where size and weight matters.
Arducam UVC Webcam Adapter Module for 12MP IMX477 High Quality Camera Module
IMX477 High Quality Camera Module converted to a webcam.
IMX477 MIPI cameras adapted to USB connection, with microphone. Also unleash the limit to push the camera to 1080P 60fps.
/ High Quality Camera Lenses /
The official Raspberry Pi High Quality camera module does not include a lens, and only comes with limited recommendations. Arducam is the one-stop solution provider for lenses on the Raspberry Pi High Quality Camera. Those will also work on the Arducam IMX477 High Quality Camera Modules.
Check all M12 Lenses for IMX477 High Quality Camera >
[Discontinued] Arducam 25mm Telephoto Noir M12 Lens Bundle for Raspberry Pi HQ Camera, with Portable Tripod Stand and 2ft/60cm Black Camera Cable
[Discontinued] Arducam 50 Degree M12 Lens Bundle for Raspberry Pi HQ Camera, with Portable Tripod Stand and 2ft/60cm Black Camera Cable
[Discontinued] Arducam 70 Degree M12 Lens Bundle for Raspberry Pi HQ Camera, with Portable Tripod Stand and 2ft/60cm Black Camera Cable
[Discontinued] Arducam 90 Degree M12 Lens Bundle for Raspberry Pi HQ Camera, Wide Angle Lens with Portable Tripod Stand and 2ft/60cm Black Camera Cable
Arducam 130 Degree M12 Lens Bundle for Raspberry Pi HQ Camera, Wide Angle Lens with Portable Tripod Stand and 2ft/60cm Black Camera Cable
[Discontinued] Arducam 180 Degree Fisheye M12 Lens Bundle for Raspberry Pi HQ Camera, Wide Angle Lens with Portable Tripod Stand and 2ft/60cm Black Camera Cable
Arducam Telephoto 20 Degree 1/2.3″ M12 Lens with Lens Adapter for Raspberry Pi High Quality Camera
Arducam 90 Degree Wide Angle 1/2.3″ M12 Lens with Lens Adapter for Raspberry Pi High Quality Camera
Arducam 130 Degree Ultra Wide Angle 1/2.3″ M12 Lens with Lens Adapter for Raspberry Pi High Quality Camera
Arducam 180 Degree Fisheye 1/2.3″ M12 Lens with Lens Adapter for Raspberry Pi High Quality Camera
Arducam M12 Lens Kit for Raspberry Pi High Quality Camera, Fisheye Wide Angle Telephoto M12 Camera Lenses with Lens Adapter
Check all CS-Mount Lenses for IMX477 High Quality Camera >
[Discontinued] Arducam CS-Mount Lens Bundle for Raspberry Pi HQ Camera, 6mm Focal Length Wide Angle CS Lens with Portable Tripod Stand and 2ft/60cm Black Camera Cable
Arducam CS-Mount Lens Kit for Raspberry Pi HQ Camera (Type 1/2.3), 6mm to 25mm Focal Lengths, 65 to 14 Degrees, Telephoto, Wide Angle, Pack of 5
Arducam CS-Mount Lens for Raspberry Pi HQ Camera, 16mm Focal Length with Manual Focus and Adjustable Aperture
Arducam Lens for Raspberry Pi HQ Camera, Wide Angle CS-Mount Lens, 6mm Focal Length with Manual Focus and Adjustable Aperture
Arducam CS-Mount Lens for Raspberry Pi HQ Camera, 8mm Focal Length with Manual Focus
Arducam CS-Mount Lens for Raspberry Pi HQ Camera, 8mm Focal Length with Manual Focus and Adjustable Aperture
Arducam CS-Mount Lens for Raspberry Pi High Quality Camera, 12mm Focal Length with Manual Focus
Arducam CS-Mount Lens for Raspberry Pi High Quality Camera, 25mm Focal Length with Manual Focus
[Discontinued] Arducam CS-Mount Lens Bundle for Raspberry Pi High Quality Camera, Wide Angle 6mm Focal Length Manual Focus Lens with Portable Tripod Stand and 2ft/60cm Black Camera Cable
Arducam Lens for Raspberry Pi High Quality Camera, Wide Angle CS-Mount Lens, 6mm Focal Length with Manual Focus
Check all C-Mount Lenses for IMX477 High Quality Camera >
Arducam 2.8-12mm Varifocal C-Mount Lens for Raspberry Pi HQ Camera, with C-CS Adapter
Arducam 4-12mm Varifocal C-Mount Lens for Raspberry Pi HQ Camera, with C-CS Adapter
[Discontinued] Arducam C-Mount Lens for Raspberry Pi High Quality Camera, 5mm Focal Length with Manual Focus and Adjustable Aperture
Arducam C-Mount Lens for Raspberry Pi High Quality Camera, 8mm Focal Length with Manual Focus and Adjustable Aperture
Arducam C-Mount Lens for Raspberry Pi High Quality Camera, 12mm Focal Length with Manual Focus and Adjustable Aperture
Arducam C-Mount Lens for Raspberry Pi High Quality Camera, 16mm Focal Length with Manual Focus and Adjustable Aperture
/ Multi-Camera & Stereo Vision /
With the solutions from Arducam, you can use not only one, but multiple cameras, on a single camera slot either on the Raspberry Pi or the NVIDIA Jetson Nano. Check out the following multi-camera solutions that help you multiplex, combine, and aggregate images.
The camarray HAT (coming soon) is used for synchronizing multiple IMX477 cameras connected to a single Pi camera slot.
/ Tripods /
Arducam Lightweight Adjustable Mini Tripod Stand with Rotation Ball for Raspberry Pi High Quality Camera
$ 20.99 -
Arducam Multi-Adjustable Tripod Stand for Raspberry Pi High Quality Camera, with 360 Ball Head and Bubble Level Indicator
Arducam Adjustable Tripod Stand with Bubble Level Indicator for Raspberry Pi High Quality Camera
Arducam Flexible Tripod Stand for Raspberry Pi High Quality Camera
Arducam Lightweight Mini Tripod Stand for Raspberry Pi High Quality Camera, with Extender
Arducam Variable Height Tripod Stand for Raspberry Pi High Quality Camera, with 360 Ball Head
Arducam Tripod Stabilizer for Raspberry Pi High Quality Camera, Variable Height Portable Camera Tripod Stand
Arducam Tripod for Raspberry Pi High Quality Camera, Mini Lightweight Portable Camera Tripod Stand
