Arducam IMX477: Best RPi High Quality Camera Alternative
high quality imx477 solutions from arducam
12MP High Quality Sony Exmor RS IMX477 interfaced with Raspberry Pi, Jetson Nano, or Arducam USB Camera Shield, with customizable optical performance.
Check the Model for NVIDIA Jetson Instead
/ Camera Modules /
Arducam 12MP IMX477 High Quality Camera Module, Basic Model, 6mm CS-Lens
Same, but different.
Same IMX477 image sensor adopted as the Raspberry Pi High Quality Camera, but way more customizable with Arducam accessories and drivers.
Arducam 12MP IMX477 High Quality Camera Module, Metal Case, CSI Extension over HDMI
Real High quality, from the inside out.
When the inside gets serious, the outside follows. Industrial level metal housing with a standard tripod mount and robust HDMI adapter to extend the connection.
Arducam 12MP IMX477 High Quality Camera Module, CS-Mount, Switchable Mechanical IR filter
You want IR sensitivity, we give you IR flexibility.
​​​​A CS-Mount IMX477 Camera Module – but NoIR or not? Thanks to the mechanical filter, the decision is yours.
Arducam 12MP IMX477 High Quality Camera Module, Motorized Focus or Software Autofocus
IMX477 made versatile as well.
Voice Coil Motor (VCM) inside to focus the lens. What you’ve liked about our V1&V2 Motorized focus Pi cam mods, now all available on the IMX477.
Arducam 12MP IMX477 High Quality Camera Module, M12 Lens, Compact V2-Size Form Factor
Compact, light-weight, and yet high quality.
​​​​Could be a smooth upgrade to drop-in replace your original V1 or V2 camera setups. Also suitable for applications where size and weight matters.
Arducam UVC Webcam Adapter Module for 12MP IMX477 High Quality Camera Module
IMX477 High Quality Camera Module converted to a webcam.
IMX477 MIPI cameras adapted to USB connection, with microphone. Also unleash the limit to push the camera to 1080P 60fps.
/ High Quality Camera Lenses /
The official Raspberry Pi High Quality camera module does not include a lens, and only comes with limited recommendations. Arducam is the one-stop solution provider for lenses on the Raspberry Pi High Quality Camera. Those will also work on the Arducam IMX477 High Quality Camera Modules.
/ Multi-Camera & Stereo Vision /
With the solutions from Arducam, you can use not only one, but multiple cameras, on a single camera slot either on the Raspberry Pi or the NVIDIA Jetson Nano. Check out the following multi-camera solutions that help you multiplex, combine, and aggregate images.
The camarray HAT (coming soon) is used for synchronizing multiple IMX477 cameras connected to a single Pi camera slot.
/ Tripods /
