Arducam Complete High Quality Camera Bundle, 12.3MP 1/2.3 Inch IMX477 HQ Camera Module with 6mm CS-Mount Lens, Metal Enclosure, Tripod and HDMI Extension Adapter for NVIDIA Jetson Nano/Xavier NX and NVIDIA Orin NX/AGX Orin
Arducam Complete High Quality Camera Bundle for Jetson Nano, 12.3MP 1/2.3 Inch IMX477 HQ Camera Module with 6mm CS-Mount Lens, Jetvariety Adapter Board, Metal Enclosure, Tripod and HDMI Extension Adapter
Arducam High Quality Camera, 12.3MP 1/2.3" 477P HQ Camera Module with 6mm CS-Mount Lens for NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
B0249
Check Raspberry Pi version SKU: B0240
  • Note: For the new version(R32 4.4), please refer to the following link: https://github.com/ArduCAM/MIPI_Camera/releases/tag/v0.0.2
  • Get Clearer Images: This camera adopts 1/2.3″ 12.3 Megapixel sensor for sharp image, max. still resolution 4056(H) x 3040(V).
  • Less Hassle: No more wasting time looking for the CS lens and camera case. A 1/2.3″ 6mm focal length CS lens is included, and the 3D file of the camera can be downloaded to print your case.
  • More Lanes: Arducam high quality camera module has a 4-lane MIPI CSI-2 interface, makes it possible to get more data through.
  • Support More Platforms: It supports Jetson Board , can also work on Raspberry Pi Zero and Compute Module. For PC /laptop, you could purchase the HQ UVC camera module?B0280?(with 6mm CS Mount Lens) or?B0288?(with Varifocal C Mount Lens) directly.
was $75.99 Special Price $59.99
Arducam 477P high-quality camera module features a three-hole pitch camera board with a 6mm CS lens. With natively hardware ISP capability, customers can use this camera module on the Jetson Board/Raspberry Pi Compute Module CM4, CM3, and CM3+.Currently, NVIDIA official has released the NVIDIA Jetson Orin series developer board. We have also adapted the camera into the NVIDIA Jetson Orin kernel based on it.
★KERNEL CAMERA DRIVER USED
  • UAV/Drones/FPV camera
  • Machine Vision
  • Robotics
  • Face Recognition
  • Defect Detection
  • Get Clearer Images: This camera adopts a 1/2.3" 12.3 Megapixel sensor for sharp image, max. still resolution 4056(H) x 3040(V).
  • Less Hassle: No more wasting time looking for the CS lens and camera case. A 1/2.3" 6mm focal length CS lens is included.
  • More Lanes: The Arducam high-quality camera module has a 4-lane MIPI CSI-2 interface to make it possible to get more data through.
  • Wide Compatibility: Specially designed for Jetson NVIDIA Orin NX/AGX Orin
Pixel Size 1.55 µm x 1.55 µm
Optical Size 1/2.3"
Focal Length 6mm
F.NO F1.2
Field of View(FOV) 78°(D)×65°(H)×51°(V)
Lens Mount CS-Mount
MOD 0.2mm
Back Focal Length 7.53mm
Lens Dimension Φ30×31mm
Electrical & Mechanical
Camera Board Size 38 × 38mm
Hole Pitch Compatible with 29mm, 30mm, 34mm
Peaking Current 300mA
  • 1 x 12MP Camera Module with 6mm CS Lens
  • 1 x 15-22pin FPC Cable
  • 1 x 22-22pin FPC Cable
  • No SBC board is included in the package
