Check Raspberry Pi version SKU: B0241
New version with ISP features, upgrade from B0243.
Note: For the new version(R32 4.4), please refer to the following link: https://github.com/ArduCAM/MIPI_Camera/releases/tag/v0.0.2
For PC /laptop, you could purchase the HQ UVC camera module?B0280?(with 6mm CS Mount Lens) or B0288 (with Varifocal C Mount Lens) directly.
NOTE:
This camera is mainly designed for the Jetson Nano. It can also be used on the Raspberry Pi Compute Module (like CM3, CM3+), but is not compatible with standard Raspberry Pi models (like Raspberry Pi 3/3B+/4).
Arducam just released this complete High Quality camera bundle for Jetson Nano/Xavier NX, an IMX477 camera board with a 6mm CS lens, a customized metal enclosure, a tripod stand, and a set extension adapter. The customers can use this camera module on Jetson Nano/Xavier NX natively with hardware ISP features.
This camera relies on kernel drivers to work – one kernel version, one camera driver.
Our IMX477 camera module support 4-lane in hardware, but the 4-lane camera driver requires extra customization. Here is why:
- Sensor: IMX477
- Optical Format: 1/2.3" (diagonal 7.857mm)
- Resolution: 4056(H) x 3040(V) 12.3MP
- Pixel Size: 1.55um x 1.55um
- IR Sensitivity: Visible light
- Interface: 4-lane MIPI CSI-2
- Default Lens Mount: CS-Mount
- Frame Rate: 4032x3040@30fps, 3840x2160@30fps, 1920x1080@60fps; Due to Jetson Xavier NX/Nano hardware only supports 4K@30fps h.264/h.265 encoding, you cannot use it for 4K@60fps.
- Frame Rate (NVIDIA Orin NX/AGX NX): 4032x3040@60fps, 1920x1080@60fps
- Format: 1/2.3 inch
- Focal Length: 6mm
- Aperture (F): Max. F1.2
- Field of View (FOV): 65° (H)
- Mount: CS-Mount
- Back Focal Length: 7.53mm
- MOD: 0.2m
- Dimension: Φ30×31mm
- Weight: 53g
| SKU | LN051 | LN050 | LN038 | LN039 | LN040 | LN041 | LN029 |
Part No |
CS17320M12 |
CS2316ZM02 |
CS2308ZM05 |
CS2008ZM05A |
CS1812ZM03 |
CS2325ZM01 |
CS1806ZM06 |
| Optical Format | 1/1.7″ | 1/2.3' | 1/2.3'' | 1/2.3'' | 1/2.3'' | 1/2.3'' | 1/2.3'' |
| EFL(mm) | 3.2 | 16.00 | 8.00 | 8.00 | 12.00 | 25.00 | 6.00 |
| BFL(mm) | 5.94 | 7.53 | 6.50 | 7.53 | 7.53 | 8.03 | 8.03 |
| F/NO | 2.0 | 1.2 | 1.4 | 1.2 | 1.6 | 1.2 | 1.4 |
| HFOV on 1/2.3‘’ Cam | 120° | 24° | 50° | 50° | 30° | 14° | 65° |
| MOD | 0.30m | 0.20m | 0.30m | 0.20m | 0.20m | 0.20m | 0.30m |
Size(mm) |
28×30 | 30×29 | 28×23 | 30×29.5 | 30×29 | 28×29 | 28×28.5 |
NOTE 1: The CS-Mount Lens kit for the HQ Camera module, please check LK004, 5 lenses are included.
NOTE 2: For the sample order, please order the lens you need to replace separately and Contact us in advance for customization if you would like to replace the lenses on the Camera board.
- Board Size: 38mm×38mm
- Hole Pitch: Compatible with 29mm, 30mm, 34mm
Identify Your Model First, identify which IMX477 camera you purchased before proceeding with the setups below. Currently, all Arducam IMX477 cameras for Jetson share the same drivers to work, but their hardware assembly may vary. B0249 B0250 B0251 Standard size board camera Camera with metal enclosure and HDMI adapter Compact size board camera Hardware Setup […]
Troubleshooting IMX477 Camera with Nano & NX (Hardware & Driver)
Full HQ Camera Dev Kit for Jetson Nano & Xavier NX (Quick Start Tutorial)
