Arducam 8MP Varifocal USB Camera Module, 4K CMOS IMX179 UVC Webcam Board with 2.8-12mm Zomm Lens, 6.56ft/2m Cable for Windows, Linux, Android and Mac OS
Arducam 130 Degree M12 Lens Bundle for Raspberry Pi HQ Camera, Wide Angle Lens with Portable Tripod Stand and 2ft/60cm Black Camera Cable
Arducam Complete High Quality Camera Bundle for Jetson Nano, 12.3MP 1/2.3 Inch IMX477 HQ Camera Module with 6mm CS-Mount Lens, Jetvariety Adapter Board, Metal Enclosure, Tripod and HDMI Extension Adapter
B0243
Note: This product was discontinued. Please check the upgrade version-SKU: B0250
Work Natively with Jetson Nano. Driver: https://github.com/ArduCAM/MIPI_Camera/tree/master/Jetson/IMX477/driver
Get Clearer Images: This camera adopts 1/2.3″ 12.3 Megapixel IMX477 sensor for sharp image, max. still resolution 4056(H) x 3040(V).
No Hassle: No more wasting time looking for the CS lens and camera case. It includes A 1/2.3″ 6mm focal length CS lens, and an?industrial?metal enclosure mounted on the camera board, the bundle also comes with a?Jetvariety adapter board, mini tripod stand and a set HDMI extension adapter.
More Lanes: The Arducam high quality camera module has a 4-lane MIPI CSI-2 interface, more than the official one, makes it possible to get more data through.
Support More Platforms: It supports all Jetson Nano A02&B01 models. For Raspberry Pi models (Pi 4, Pi?3/3B+/3A+, CM3/3+, Pi Zero, and more), you need to remove the Jetvariety adapter board and connect the camera cable to Raspberry Pi (camera cable included). For PC/laptop, you need a camera shield and a MIPI adapter board, please search for USB2 camera shield B0175 or USB3 camera shield B0111, and MIPI adapter board B0123.
The official Pi HQ camera is only available in one model. It doesn't include a lens and a case, and only comes with limited recommendations. To solve these pain points and implement the applications on Jetson Naon, Arducam released this complete camera bundle, an IMX477 camera board with a 6mm CS lens, a customized metal enclosure, a Jetson Nano adapter board, a tripod stand and a set extension adapter. This camera module supports Jetson Nano as well as all Raspberry Pi models and PC/laptop (need MIPI adapter board and USB camera shield, not included).
IMPORTANT NOTE ON THE IMX477 MIPI LANES
Specs
- Sensor: IMX477 - Optical Format: 1/2.3" (diagonal 7.857mm) - Resolution: 4056(H) x 3040(V) 12.3MP - Pixel Size: 1.55um x 1.55um - IR Sensitivity: Visible light - Interface: 4-lane MIPI CSI-2 - Default Lens Mount: CS-Mount - Frame Rate: (depends on the target platform, maximum fps limit might apply) 1920x1080 @ 60fps4032x3040 @ 30fps
- Format: 1/2.3 inch - Focal Length: 6mm - Aperture (F): Max. F1.2 - Field of View (FOV): 65° (H) - Mount: CS-Mount - Back Focal Length: 7.53mm - MOD: 0.2m - Dimension: Φ30×31mm - Weight: 53g
1 pcs complete 12.3MP IMX477 color camera mounted in a metal encolsure
1 pcs 1/2.3 inch 6mm focal length CS-mount lens and
1 pcs HDMI-CSI camera adapter board with 60mm/2.36inch 15 pin camera cable
1 pcs Jetvariety adapter board
1 pcs 1m high-speed HDMI cable
1 pcs mini tripod stand
1 pcs 150mm/6inch 15 pin camera cable
1 pcs 73mm/2.9inch 15 pin to 22 pin camera cable for Raspberry Pi Zero&W
