Arducam 12MP 477P Mini High Quality Camera Module for Raspberry Pi and Pi zero
Arducam  12.3MP IMX477 Camera Module w/ C/CS-Lens Mount and Tripod Adapter for Raspberry Pi
Arducam 477P High Quality Camera for Raspberry Pi, 12.3MP 1/2.3 Inch HQ Camera Module with 6mm CS Lens for Pi 4B, 3B+, 2B, 3A+, Pi Zero and more
B0240
  • Clearer Images: Based on 1/2.3″ 12.3 Megapixel sensor for sharp image, max still resolution 4056(H) x 3040(V).
  • Less Hassle: Including 1/2.3″ 6mm focal length CS lens and the 3D file of the camera can be downloaded to print your case.
  • Refer to B0241 to get the camera bundle with the metal enclosure.
  • Wide Compatibility: It supports all Raspberry Pi camera models.
  • For Nvidia Jetson Nano and Xavier NX, refer to B0249 / B0250. For PC /laptop, you could purchase the HQ UVC camera module?B0280?(with 6mm CS Mount Lens) or?B0288?(with Varifocal C Mount Lens) directly.
was $79.99 Special Price $59.99
The official Pi HQ camera is only available in one model. It doesn't come with a lens and it is also not easy for the users to find a case. To solve these pain points, Arducam released this camera module, a customized 477P camera board with three-hole pitches and a 6mm CS lens. And you can download our 3D files to print your case as you like.
  • UAV/Drones/FPV camera
  • Machine Vision
  • Robotics
  • Face Recognition
  • Defect Detection
  • High Quality Camera: Adopts a 1/2.3″ 12 Megapixel sensor for sharp image, max. still resolution 4056 x 3040.
  • Less Hassle: Including 1/2.3″ 6mm focal length CS lens and the 3D file.
  • More Than Ultra HD: Come with an interchangeable CS lens with a FOV of 65°(H), which can capture UHD images while maintaining reality.
  • Wide Compatibility: Not only compatible with Raspberry Pi 1, 2, 3, and 4, but also with Raspberry Pi Zero and Zero 2W.
  • Native to Raspberry Pi: No need to install additional driver for this camera
Video Modes 2028 × 1080p50, 2028 × 1520p40 and 1332 × 990p120
Pixel Size 1.55 µm x 1.55 µm
Optical Size 1/2.3"
Focal Length 6mm
F.NO F1.2
Field of View(FOV) 65°(H)
Lens Mount CS-Mount
MOD 0.2mm
Back Focal Length 7.53mm
Lens Dimension Φ30×31mm
Electrical & Mechanical
Camera Board Size 38 × 38mm
Hole Pitch Compatible with 29mm, 30mm, 34mm
Peaking Current 300mA
  • 1 x 12MP Camera Module with 6mm CS Lens
  • 1 x 300mm/11.8inch 15pin to 15pin camera cable
  • 1 x 300mm/11.8inch 15pin to 22pin camera cable
