Cameras for Raspberry Pi
  3. Cameras for Raspberry Pi
  4. Native Raspberry Pi Cameras
  5. 12MP IMX477 Standard Camera Module
Arducam IMX477 cameras support all Raspberry Pi camera models. Pi 4, Pi 3/3B+/3A+, CM3/3+, Pi Zero, and more. Unlike the official high quality camera has only one hole pitch, Arducam IMX477 cameras offer 3 hole pitches 29mm, 30mm, 34mm. compatible with standard industrial camera enclosure. What’s more, they have a 4-lane MIPI CSI-2 interface, more than the official one, which makes it possible to get more data through.
Models in this Series
Currently, there are 3 models in Arducam IMX477 Standard Camera Series. The main difference between them is the board size, default lens and accessories.
SKUB0240B0241B0262
Board Size38×38 mm38×38 mm25×24 mm
Default LensCSCSM12
Tripod××
Metal Enclosure××
Weight70g203g10g
Output Interface4-lane MIPI CSI-24-lane MIPI CSI-22-lane MIPI CSI-2
  • Get B0240 for a standard version with a CS lens.
  • Get B0241 for a bundle version with a metal enclosure and tripod.
  • Get B0262 for a mini version with M12 Lens.
Common Specs
The following specs applies to all products in this series.
Image sensor
Sensor ModelIMX477
Shutter TypeRolling Shutter
IR SensitivityVisible light
Active Pixels4056×3040
Resolution12 MP
Image Sensor Format1/2.3″
Pixel Size1.55μm×1.55μm
Video Modes on Raspberry Pi1080p30, 720p60 and 640 × 480p60/90
SKUB0240B0241B0262
InterchangeabilityInterchangeableInterchangeableInterchangeable
F/NO1.21.22.8
Focus TypeManual FocusManual FocusManual Focus
MOD0.1 m0.1 m0.3 m
Lens Focal Length6mm6mm3.9mm
Field of View(FoV)65° (H)65° (H)65° (H)
Lens OptionCS/C/M12CS/C/M12M12 only
Back Focal Length7.53mm7.53mm4.49mm
Lens DimentionΦ30×31mmΦ30×31mmΦ14×18.67mm
Connector & Cable
SKUB0240B0241B0262
Camera ConnectorMIPI CSI-2 22-pinMIPI CSI-2 22-pinMIPI CSI-2 22-pin
Cable Length80mm (22-pin), 300mm(15-22pin)73mm(15-22pin), 1m(HDMI cable)80mm (22-pin), 150mm(15-22pin)
Pin #NameDescription
1GNDGround
2CAM_D0_NMIPI Data Lane 0 Negative
3CAM_D0_PMIPI Data Lane 0 Positive
4GNDGround
5CAM_D1_NMIPI Data Lane 1 Negative
6CAM_D1_PMIPI Data Lane 1 Positive
7GNDGround
8CAM_CK_NMIPI Clock Lane Negative
9CAM_CK_PMIPI Clock Lane Positive
10GNDGround
11CAM_D2_NMIPI Data Lane 2 Negative
12CAM_D2_PMIPI Data Lane 2 Positive
13GNDGround
14CAM_D3_NMIPI Data Lane 3 Negative
15CAM_D3_PMIPI Data Lane 3 Positive
16GNDGround
17CAM_IO0Power Enable
18CAM_IO1LED Indicator
19GNDGround
20SCLI2C SCL
21SDASCCB serial Interface data IO
22VCC3.3V Power Supply
Quick Start Guide
Note:
If you are running the latest version of Raspberry Pi OS. (January 28th, 2022 or later releases, Debian version: 11 (Bullseye)). You need to update the config file and use libcamera apps.
  • For Raspberry Bullseye users running on Pi 4, please do the following:
sudo nano /boot/config.txt
Find the line: camera_auto_detect=1, update it to:
camera_auto_detect=0
dtoverlay=imx477
Save and reboot.
  • For Bullseye users running on Pi 0 ~ 3, please also:
Open a terminal
Run sudo raspi-config
Navigate to Advanced Options
Reboot your Pi
Open a terminal
Navigate to GL Driver
Select GL (Full KMS)
Reboot your Pi
  • For Raspberry Pi Compute Module 3/4
The latest software only supports one camera at this time, CM4 uses CAM1 by default.
If you are running the previous system (Buster legacy and the system before it), you can refer to the below link.
Getting started with Raspberry Pi
FAQ/Troubleshooting
The use of the four Raspberry Pi camera applications
FAQ about raspberry pi camera module
Was this article helpful to you? Yes 2 No 1
