Designed for seamless integration with Raspberry Pi ecosystems, this camera module combines native V4L2 driver compatibility and a 12.3MP SONY image sensor for high-fidelity imaging. Featuring interchangeable CS/C-mount optics and MIPI CSI-2 interface, it supports rapid deployment in robotics, IoT, and industrial vision applications. The open-source design enables GPIO-driven customization and redevelopment via Raspberry Pi.
As a pioneer in embedded imaging, Arducam offers tailored camera solutions with advanced features like multi-camera synchronization, IR spectrum adaptation, and custom lens calibration — empowering developers to scale vision systems from prototype to production.
DSLR Camera Control
Time-lapse Machine
Security System
Remote Viewing Camera
Instant (Polaroid-Style) Camera, etc.
Embedded driver compatibility with Linux Video4Linux2 framework enables direct /dev/videoX device access, leveraging Raspberry Pi's GPU-accelerated libcamera pipeline for <3ms latency in RAW image acquisition.
Interchangeable lens system supports 12.5mm flange back distance (±5µm tolerance) with anti-reflective coating, supporting Ø25.4mm C-mount lenses with large aperture for low TV distortion.
22-pin FPC connector implements MIPI D-PHY protocol (High bandwidth) with <0.1UI jitter, compatible with all Raspberry Pi embedded platforms.
Seamless compatibility with Raspberry Pi ecosystem and official OS distributions (Bookworm/Bullseye), supported by 150,000+ community-driven projects on GitHub and ROS (Robot OS) packages for rapid prototyping.
Still Resolution
12.3 Megapixels
Video Modes
2028 x1080p50, 2028x1520p40 and 1332x990p120
Sensor Resolution
4056 x 3040 pixels
Sensor image area
6.287mm x 4.712 mm (7.9mm diagonal)
Pixel Size
1.55 µm x 1.55 µm
Optical Size
1/2.3"
IR Sensitivity
Integral 650nm IR Filter, visible light only
Compatibility & Mechanical
Supported Platform
Raspberry Pi 5/4B/3B+/3/2/CM3/CM4/CM5/Zero W/Zero 2 W
Supported OS
Bookworm/Bullseye
Camera Board Size
38mm x 38mm
1 x 12.3MP Camera Board with C-CS Adapter and Tripod Adapter
1 x 150mm 15pin to 22pin camera cable for Pi 5
1 x 150mm 15pin to 15pin camera cable for Pi 4B/3b+
Raspberry Pi board is not included in the package
The C/CS lens is not included in the package
The tripod is not included in the package. If you need it, please refer to: UB0216
Products with electrical plugs are designed for use in the US. Outlets and voltage differ internationally and this product may require an adapter or converter for use in your destination. Please check compatibility before purchasing
