Synchronized Stereo Camera HAT for Raspberry Pi
Arducam 2MP OV2640 1/4” Camera Breakout Board
[Discontinued] Arducam NoIR IMX219-AF Programmable/Auto Focus IR Sensitive Camera Module for NVIDIA Jetson Nano/Xavier NX
B0189
Discontinued, check alternative item B0181
was $39.99 Special Price $23.99
This Arducam IMX219AF camera module is designed mainly for the NVIDIA Jetson Nano platform and also can be used on other hardware like ARM, DSP, FPGA, etc.
The highlight of this camera is that the lens focus is programmable by software, and the Arducam team provides an opensource code to implement software autofocus features on the Jetson Nano.
★KERNEL CAMERA DRIVER USED
Image Sensor IMX219
Still Resolution 8 Megapixels
3280x2464@21fps, 3280x1848@28fps, 1920x1080@30fps, 1640x1232@30fps, 1280x720@60fps
Pixel Size 1.12 µm x 1.12 µm
Optical Size 1/4"
IR Sensitivity without IR-cut filter, sensitive to IR light
Focus Type Programmable/Auto Focus
Focal Length 2.8mm
F.NO F2.2
Field of View(FOV) 65°(H)×51°(V)×77.6°(D)
Focus Distance 80mm~infinity
Electrical & Mechanical
Camera Board Size 25 x 24mm
Peaking Current 300mA
  • Unmanned Aerial Vehicles (UAVs)
  • Building Drones
  • Autonomous Robotic Systems
  • Mobile Medical Imaging
  • Intelligent Video Analytics (IVA)
Package Includes
  • 1pcs Arducam IMX219-AF Programmable/Auto Focus IR Sensitive (NoIR) Camera Module
  • 1pcs 15cm 15-15pin FPC cable
  • 1pcs 15cm 15-22pin FPC cable
Used on Pi
8MP IMX219 Motorized Focus Camera Module
Introduction Arducam 8MP IMX219 Motorized Focus Camera Modules are designed for you to control the focus via software, so you can see closer and see where you want to see. To learn more about autofocus with Raspberry Pi camera modules, we recommend you read Raspberry Pi Camera Autofocus: The Complete Guide. Models in this Series There […]
Used on Jetson
IMX219 – Motorized Focus Camera
Introduction The autofocus camera is an advanced IMX219 camera module for Jetson Nano/Xavier NX board. It helps to focus the object in close range from 5cm~30cm, within this range the standard fixed focus camera can not get sharp focus and the image looks burry. All the focus procedure is controlled by the software without manually […]
3D drawing.STP
2 comments
GitHub
ArduCAM/Nvidia_Jetson
