16MP IMX519 Camera Module with 122°(D) M12 Lens, Wide Angle Color Rolling shutter for Raspberry Pi and OpenHD
Ribbon Cable Set (1.5″, 2.87″, 5.9″) for Raspberry Pi 0 and Zero 2W, Pack of 3
Mini 16MP IMX519 NoIR Camera Module for Raspberry Pi 5,Raspberry Pi 0 and Zero 2W
B0391
  • Minified: super compact form factor.
  • No Infrared Filter: perfect for night vision & multispectral applications.
  • 16 Megapixel: 2 times higher res than v2.
  • Fixed-Focus: great for UAVs, drones, robots, etc.
  • Highly Compatible: libcamera-ready, works with all Pi models.
  • Field of View(FOV): 66°(H) x 49.5°(V) x 80°(D)
arducam shipping payment 1
$32.99
A minified version of the 16MP camera with a fixed focus lens and a 22-pin CSI-2 connection specifically built for Raspberry Pi Zero and Zero 2W
This module does not have built-in IR filters and is capable of night vision and multispectral applications. We also have an entire list of minified modules, including the official V1/V2/HQ cameras, built for Pi.
Stills/videos taken under natural daylight will be heavily affected by infrared (see above video), if you don't need IR sensibility, please get the standard 16MP-AF or 16MP-Mini instead.
See other options of our 16MP series >
Sensor Sony IMX519 stacked, back-illuminated sensor 16 megapixels 1.22 µm × 1.22 µm pixel size7.103 mm diagonal (Type 1/2.534)
Output RAW10/8, COMP8
Lens f/1.75; EFL: 4.28
Field of View(FOV) 66°(H) x 49.5°(V) x 80°(D)
IR Filter Without IR-cut filter, sensitive to infrared light
Video Modes 1080p@30fps, 720p@60fps
Linux integration V4L2 driver available
Ribbon Cable Length 60mm
Packing Including
  • 1 x Arducam 16MP-Mini-NoIR
FaQs
Is this camera compatible with all Raspberry Pi Models?
Yes.
Do I need external IR LEDs if want to use the camera in complete dark?
Yes, IR LEDs are requried if you want to use it for night vision projects.
