Arducam IMX219 Auto Focus Camera Module, drop-in replacement for Raspberry Pi V2 and NVIDIA Jetson Camera
Arducam IMX219 Wide Angle Camera Module, drop in replacement for Raspberry Pi V2 and NVIDIA Jetson Camera
Arducam IMX219 Low Distortion M12 Mount Camera Module, drop-in replacement for Raspberry Pi V2 Camera and NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
B0184
  • Easy installation: Just detach the original stock IMX219 module onboard and re-attach this replacement
  • Low Distortion: 70°(H) Low-Distortion (<3%) M12 Lens, minimize the image distortion and wide angle
  • Please note that the Raspberry Pi V2 Camera board is not included
was $24.99 Special Price $13.99
This Arducam IMX219 low distortion lens camera module is designed mainly for Raspberry Pi V2 camera board and Nvidia Jetson Board, replacing the default standard IMX219 camera module to get a low distortion of view (<3%). It can be used for drone, robot, action camera and 3D scanning applications.
★KERNEL CAMERA DRIVER USED
  • Drone, robot
  • Action Camera
  • 3D scanning applications
  • Field animal camera
  • Recording slow motion
  • Machine vision, etc.
Image Sensor IMX219
Still Resolution 8 Megapixels
Pixel Size 1.12 µm x 1.12 µm
Optical Size 1/4"
Focal Length 2.8mm
Field of View(FOV) 75°(H)
Electrical & Mechanical
CSI-2 Data Output 2-lane mode
Peaking Current 300mA
  • 1 x Arducam IMX219 Low Distortion M12 Mount Camera Module
Raspberry Pi 5 √ √
Used on Pi
8MP IMX219 Standard Camera Modules
Introduction Arducam team just released an 8MP Raspberry Pi compatible camera based on the same Sony IMX219 image sensor. It’s capable of 3280 x 2464 pixel static images, and also supports 1080p30, 720p60 and 640x480p90 video. It attaches to Pi by the dedicated standard CSi interface. It is supplementary for Raspberry Pi official camera in […]
Used on Jetson
IMX219 – 8MP Camera
3D drawing_case.step
2 comments
    Lens  options
    SKU Format FOV on 1/4” sensor Focal Length
    LN006 1/4’’ 100° 1.8mm
    LN008 1/2.5’’ 140° 1.56mm
    LN011 1/2.5’’ 45° 4mm
    LN012 1/2.5’’ 55° 3.6mm
    LN013 1/2.7’’ 75° 2.8mm
    LN014 1/2.7’’ 90° 2.1mm
    LN015 1/4’’ 63° 3.2mm
    Selection Guide
    Edit
    B0055 5MP M12 Fisheye 5MP RGB rolling shutter
