Arducam IMX219 Low Distortion M12 Mount Camera Module, drop-in replacement for Raspberry Pi V2 Camera and NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
Arducam Sensor Extension Cable for Raspberry Pi Camera Module V2, 300MM/1FT Cable to Extend IMX219 Sensor for Smaller Enclosure, Narrow Space and Spy Camera Project, Work with V2 Camera on Jetson Board
Arducam IMX219 Wide Angle Camera Module, drop in replacement for Raspberry Pi V2 and NVIDIA Jetson Camera
B0180
  • Easy installation: Just detach the original stock IMX219 module onboard and re-attach this replacement
  • Wider Angle of View: 175°(D) wide-angle Lens, which provides a much wider view
  • Replaceable Lens: Various M12 Lens for your different requirement
  • Various Application: Drones, robots, action cameras and 3D scanning applications, home security system, etc.
was $24.99 Special Price $9.99
This Arducam IMX219 fisheye lens camera module is designed mainly for Raspberry Pi V2 camera board and Nvidia Jetson Board, replacing the default standard IMX219 camera module to get a much wide field of view. It can be used for drones, robots, action cameras, and 3D scanning applications.
KERNEL CAMERA DRIVER USED
SUPPORTED PLATFORM DISCLAIMER
Image Sensor IMX219
Still Resolution 8 Megapixels
Pixel Size 1.12 µm x 1.12 µm
Optical Size 1/4"
Focal Length 1.3mm
F.NO F2.0
Field of View(FOV) 175°(D)×155°(H)×115°(V),
Electrical & Mechanical
CSI-2 Data Output 2-lane mode
Peaking Current 300mA
  • 1 x Arducam IMX219 Wide Angle Camera Module
Raspberry Pi 5
Used on Pi
8MP IMX219 Standard Camera Modules
Introduction Arducam team just released an 8MP Raspberry Pi compatible camera based on the same Sony IMX219 image sensor. It’s capable of 3280 x 2464 pixel static images, and also supports 1080p30, 720p60 and 640x480p90 video. It attaches to Pi by the dedicated standard CSi interface. It is supplementary for Raspberry Pi official camera in […]
Used on Jetson
IMX219 – 8MP Camera
3D drawing.step
3D drawing_case.step
3D Drawing
2 comments
Lens  options
SKU Format FOV on 1/4” sensor Focal Length
LN006 1/4’’ 100° 1.8mm
LN008 1/2.5’’ 140° 1.56mm
LN011 1/2.5’’ 45° 4mm
LN012 1/2.5’’ 55° 3.6mm
LN013 1/2.7’’ 75° 2.8mm
LN014 1/2.7’’ 90° 2.1mm
LN015 1/4’’ 63° 3.2mm
