Arducam IMX219 Auto Focus IR Sensitive (NoIR) Camera Module, drop-in replacement for Raspberry Pi V2 and NVIDIA Jetson Camera
Arducam IMX219 Low Distortion M12 Mount Camera Module, drop-in replacement for Raspberry Pi V2 Camera and NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
Arducam IMX219 Auto Focus Camera Module, drop-in replacement for Raspberry Pi V2 and NVIDIA Jetson Camera
B0182
  • Native to Raspberry Pi: You don’t need to install additional driver for the camera
  • Programmable Autofocus: Software controll, focus closer. See Arducam Github for more details
  • Control Precisely: You can use “UP” and “Down” on your keyboard to adjust the focus manually
was $24.99 Special Price $12.99
This Arducam IMX219 fisheye lens camera module is designed mainly for Raspberry Pi V2 camera board and replace the default standard IMX219 camera module with the auto focus one. It can be used for drone, robot, action camera and 3D scanning applications.
The highlight of this camera is that the lens focus is programmable by software, and Arducam team provide an opensource code to implement software auto-focus function for Jetson Board.
★KERNEL CAMERA DRIVER USED
Application
  • Unmanned Aerial Vehicles (UAVs)
  • Building Drones
  • Autonomous Robotic Systems
  • Mobile Medical Imaging
  • Intelligent Video Analytics (IVA)
Image Sensor IMX219
Still Resolution 8 Megapixels
Pixel Size 1.12 µm x 1.12 µm
Optical Size 1/4"
Focus Type Programmable/Auto Focus
Focal Length 2.8mm
F.NO F2.2
Field of View(FOV) 78°(D)×65°(H)×51°(V)
Lens Type Stock Lens
Focus Distance 80mm to infinity
Electrical & Mechanical
Peaking Current 300mA
  • 1 x Arducam IMX219 Auto Focus Camera Module
Raspberry Pi 5 √ √
Used on Pi
8MP IMX219 Motorized Focus Camera Module
Introduction Arducam 8MP IMX219 Motorized Focus Camera Modules are designed for you to control the focus via software, so you can see closer and see where you want to see. To learn more about autofocus with Raspberry Pi camera modules, we recommend you read Raspberry Pi Camera Autofocus: The Complete Guide. Models in this Series There […]
Used on Jetson
IMX219 – Motorized Focus Camera
Introduction The autofocus camera is an advanced IMX219 camera module for Jetson Nano/Xavier NX board. It helps to focus the object in close range from 5cm~30cm, within this range the standard fixed focus camera can not get sharp focus and the image looks burry. All the focus procedure is controlled by the software without manually […]
3D drawing.step
3D drawing.step
2 comments
    Selection Guide
    Edit
