Arducam 16MP Wide Angle USB Camera, 1/2.8
Arducam 16MP Wide Angle USB Camera, 1/2.8" CMOS IMX298 4K Video Webcam With Microphone
Arducam 1080P Low Light WDR USB Camera Module with Metal Case, 2MP 1/2.8
Arducam 1080P Low Light WDR USB Camera Module with Metal Case, 2MP 1/2.8" CMOS IMX291 160 Degree Ultra Wide Angle Mini UVC Webcam Board with Microphone, 3.3ft/1m Cable for Windows Linux Mac OS
Arducam Fisheye Low Light USB Camera for Computer, 2MP 1080P IMX291 Wide Angle Mini H.264 UVC Video Camera Board with Microphone
B0261
  • HD and Low Light: This camera adopts the 2MP 1/2.8” IMX291 Color COMS sensor with an 80DB wide dynamic range, can capture the minimum illumination 0.001Lux.
  • Real Fisheye: Mounted a high quality 175°(D) wide-angle M12 Lens, which provides the most widely Field of View compared to other lenses in the series.
  • Plug&Play: UVC-compliant, support Windows XP/7/8/10, Linux, and Mac OS, just connect the camera to PC, laptop or Raspberry Pi with the USB cable without extra drivers to be installed. For Mac OS, please please open the native software facetime and select the video camera “USB Camera”.
  • Applications: The features of fisheye imaging, low light and small size help the camera board perform better in the video surveillance system, baby camera, dashcam, and other vision applications.
$57.99
Arducam IMX291 Low Light Camera Module Series is based on Sony 2MP 1/2.8” IMX291 image sensor and UVC compliant USB 2.0 cameras.
This camera B0261 is a new member of the family, which adopts a fisheye M12 lens so as to provide a wider angle of view than others.
Applications:
  • Video conference
  • Day&night low light vision security camera system
  • Dash cam
  • Monitoring 3D printer
  • Baby Camera
  • Robot and machine vision
Features & Specs
  • Sensor: 1/2.8” IMX291
  • Resolution: 2MP 1945H x 1109V
  • Data Format: MJPG/YUY2/H.264
  • Frame Rate: MJPG: 30fps@1920×1080/1280×720/800×600/640×480/320×240
    YUV: 5fps@1920×1080; 10fps@1280×720/800×600; 30fps@640×480/320×240
    H.264: 30fps@1920×1080/1280×720@30fps/800×600/640×480/320×240
  • Dynamic Range: 80DB
  • USB Connector: B4B-ZR(LF)(SN)
  • Optical Format: 1/2.5”
  • Field of View (FOV):D= 175°
  • Lens Mount: M12
  • Auto Controlled Features: Saturation, Contrast, Acutance, White balance, Exposure.
  • Audio: Single microphone (optional dual channel)
  • System Compatibility: Windows, Linux, Android, and Mac with UVC
Power
  • Power Supply: USB powered 5V
  • Working Current: MAX 300mA
Physical
  • Operating Temp.: -4°F~158°F (-20°C~+70°C)
  • Dimension: 38mmx38mm (Mount compatible with 34x34mm and 28x28mm)
  • Cable Length: 3.3ft (1M)
    Lens option
    SKU LN001 LN065 LN002 LN003 LN011 LN012 LN013 LN005 LN055 LN007
    Model No: M2516ZH01 M2512ZH03 M2508ZH02 M2506ZH04 M2504ZH05S M25360H06S M27280M07S M27210H08 M27195H15 M25170H12
    Optical Format 1/2.5'' 1/2.5'' 1/2.5'' 1/2.5'' 1/2.5'' 1/2.5'' 1/2.7'' 1/2.7'' 1/2.7'' 1/2.5''
    EFL(mm) 16 12 8 6 4 3.6 2.8 2.1 1.95 1.7
    BFL(mm) 7.1 6.5 8.1 7.3 3.24 2.75 2.6 6.3 3.8 4.7
    Construction 6G+IR 6G+IR 6G+IR 6G+IR 2G2P+IR 2G2P+IR 2G2P+IR 6G+IR 6G+IR 6G+IR
    F/NO 2.0 2.0 2.0 2.0 2.8 3.0 2.8 2.0 2.0 2.0
    FOV (D/H/V) on 1/2.7‘’ Cam 25/22/12 31/27/15 48/42/25 64/57/34 80/72/45 90/82/52 103/95/63 136/130/101 158/155/136 180/180/180
    FOV (D/H/V) on 1/2.8‘’ Cam 23/20/11 29/25/14 45/40/23 62/55/33 78/70/43 88/80/50 98/90/59 131/125/94 154/150/129 180/180/180
    FOV (D/H/V) on 1/2.9‘’ Cam 20/18/10 26/23/13 43/38/22 60/53/32 76/68/42 86/78/49 93/85/55 127/120/89 149/145/121 180/180/180
    IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter 650 IR filter
    MOD 0.3m 0.3m 0.3m 0.3m 0.3m 0.2m 0.3m 0.3m 0.2m 0.2m
    Size(mm) 14 x 16.2 14 x 16.7 14 x 16.9 14 x 17.4 14 x 18.7 14 x 16.3 14 x 15.6 14 x 15.2 17.5 x 19.9 20 x 18.7
    NOTE: The M12 Lens kit for the USB Camera module, please check LK005, 10 lenses are included.
    • 1 × 2MP IMX291 USB 2.0 camera board
    3D drawing.step
    3D drawing.step
