Arducam Fisheye Low Light USB Camera for Computer, 2MP 1080P IMX291 Wide Angle Mini H.264 UVC Video Camera Board with Microphone
[Discontinued] 1080P HD Wide Angle WDR USB Camera Module, 2MP 1/2.7
[Discontinued] 1080P HD Wide Angle WDR USB Camera Module, 2MP 1/2.7" CMOS AR0230 100 Degree Mini UVC USB2.0 Webcam
Arducam 1080P Low Light WDR USB Camera Module with Metal Case, 2MP 1/2.8" CMOS IMX291 160 Degree Ultra Wide Angle Mini UVC Webcam Board with Microphone, 3.3ft/1m Cable for Windows Linux Mac OS
UB020201
  • HD Resolution and Low Light: This camera adopts the SONY 2MP 1/2.8” IMX291 Color COMS sensor with an 80dB wide dynamic range, can capture the minimum illumination 0.001Lux.
  • Ultra Wide Angle: High quality 160 degree super wide view angle (diagonal) M12 lens with IR filter.
  • Audio, dual stereo microphones.
  • Plug&Play: UVC-compliant, support Windows XP/7/8/10, Linux, and Mac OS, just connect the camera to your computer, laptop or Raspberry Pi with the USB cable without extra drivers to be installed.
  • Applications: this tiny camera board with metal case can be placed in most hidden and narrow position for a home video surveillance system, day&night low light vision security camera system, dashcam or other machine vision application.
$60.99
The UB020201 is a new member of the Arducam’s USB camera family. Based on the 1/2.8” Sony IMX291 image sensor, it’s a 2MP, UVC compliant, ultra wide angle, low light, high speed USB 2.0 camera with metal case.
This SONY 2MP IMX291 color COMS sensor produces the camera with an 80DB wide dynamic range, can capture the minimum illumination 0.001Lux, which gives you a wider angle of view and clearer visual joy for day and night.
Applications:
  • Video conference
  • Day&night low light vision security camera system
  • Dash cam
  • Monitoring 3D printer
  • Baby Camera
  • Robot and machine vision
Features & Specs
  • Sensor: 1/2.8” IMX291
  • Resolution: 2MP 1945H x 1109V
  • Data Format: MJPG/YUY2/H.264
  • Frame Rate: MJPG: 30fps@1920×1080/1280×720/800×600/640×480/320×240
    YUV: 5fps@1920×1080; 10fps@1280×720/800×600; 30fps@640×480/320×240
    H.264: 30fps@1920×1080/1280×720@30fps/800×600/640×480/320×240
  • Dynamic Range: 80dB
  • Field of View (FOV):D= 160°
  • Lens Mount: M12
  • Focusing Range: 6.56ft (2M) to infinity
  • Auto Controlled Features: Saturation, Contrast, Acutance, White balance, Exposure.
  • Audio: Single microphone (optional dual channel)
  • System Compatibility: Windows, Linux, Android, and Mac with UVC
Power
  • Power Supply: USB powered 5V
  • Working Current: MAX 300mA
Physical
  • Operating Temp.: -4°F~167°F (-20°C~+75°C).
  • Dimension: 1.73"×1.4"
  • Cable Length: 3.3ft (1M)
  • User Guide
  • 3D Drawing
  • Package Including
    • 1 × 2MP IMX291 USB 2.0 camera board with metal case
