Arducam 12MP*2 Synchronized Stereo Camera Bundle Kit for NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX, Two 12.3MP 477P Camera Modules with CS Lens and Camarray Stereo Camera HAT
Arducam Complete High Quality Camera Bundle, 12.3MP 1/2.3 Inch IMX477 HQ Camera Module with 6mm CS-Mount Lens, Metal Enclosure, Tripod and HDMI Extension Adapter for NVIDIA Jetson Nano/Xavier NX and NVIDIA Orin NX/AGX Orin
Arducam MINI High Quality Camera with M12 mount lens, 12.3MP 1/2.3" 477P HQ Camera Module for NVIDIA® Jetson AGX Orin/Orin Nano/Orin NX
B0251
Note: For the new version(R32 4.4), please refer to the following link: Arducam Github -MIPI Camera
Check Raspberry Pi version SKU:?B0262
was $64.99 Special Price $59.99
Arducam released this small-size camera module for Jetson to make High-Quality camera module work on applications with size and weight limits. It is fully compatible with Raspberry Pi V2 module size, a 24mm x 25mm camera board, and a low-distortion M12 mount lens. Customers can natively use this camera module on Jetson Board with hardware ISP features.Currently, NVIDIA official has released the NVIDIA Jetson Orin series developer board. We have also adapted the camera into the NVIDIA Jetson Orin kernel based on it.
★KERNEL CAMERA DRIVER USED
  • UAV/Drones/FPV camera
  • Machine Vision
  • Robotics
  • Face Recognition
  • Defect Detection
  • High-Quality Camera: Adopts a 1/2.3" 12 Megapixel sensor for sharp image, max. still resolution 4056 x 3040;
  • Mini Sized HQ Cam: Mini and Lightweight: 24mm x 25mm camera board, as mini as Raspberry Pi V2 module size, mounted an M12 lens, perfect for the camera applications where high resolution is required, but size and weight are limited, such as model airplane.
  • More Than Ultra HD: Come with a low-distortion M12 lens with a FOV of 75°(H), which can capture UHD images while maintaining reality.
  • Wide Compatibility: Specially designed for NVIDIA Orin NX/AGX Orin
Pixel Size 1.55 µm x 1.55 µm
Optical Size 1/2.3"
Focal Length 3.9mm
Field of View(FOV) 88°(D)×75°(H)
Lens Mount M12
Electrical & Mechanical
Camera Board Size 25 × 24mm
  • 1 x 12MP Camera Module with M12 Lens
  • 1 x 150mm/5.9inch 15pin to 22pin FPC cable
  • 1 x 150mm/5.9inch 22pin to 22pin FPC cable
  • No SBC board is included in the package
Troubleshooting IMX477 Camera with Nano & NX (Hardware & Driver)
Mini HQ Camera Module & M12 Lens for Nano & NX Tutorial
