[Discontinued] Arducam Pico4ML TinyML Dev Kit: RP2040 Board w/ QVGA Camera, LCD Screen, Onboard Audio, Reset Button & More
[Discontinued] Arducam 20MP IMX283 Camera module with C mount lens for DepthAI OAK
[Discontinued] Arducam 8MP Synchronized Stereo Camera Bundle Kit for Jetson Nano/Xavier NX With Fisheye Lens
B0298N
Discontinued, check alternative item B0265N, B0396
Check Raspberry Pi version SKU: B0298R
$144.99
As part of Arducam Camarray multi-camera solutions, Arducam released this Synchronized Stereo Camera Bundle Kit for Jetson Nano/Xavier NX, which allows customers to connect two 8MP IMX219 cameras to a single Jetson Nano/Xavier NX board, and takes images or video at the same time, even more important they are fully synchronized. The highlight of this kit is that it incorporates Arducam proprietary ArduChip solution, and extends the usage of the single Jetson Nano/Xavier NX camera port, it cheats the board as if only one camera connected.
Driver Features
  • Support Ardcuam Stereo Camera HAT
  • Support Official IMX219 driver, Video Nodes, and Controls (Exposure, Gain and depending on camera parameters)
  • Stereo Vision
  • 360° Camera
  • Advanced Surveillance Camera
  • Enhanced Vision Goggles
Specifications:
- Camarray Stereo Camera HAT
  • Support 1, 2 lane MIPI cameras input up-to 1Gbps/lane
  • Support 2 lane MIPI output
  • Support digital pan in half resolution combine, programmable pan speed control
  • HAT size: 65 x 56 mm
- Camera
  • Sensor: IMX219
  • Optical Format: 1/4" (diagonal 7.857mm)
  • Resolution: 3280(H)×2464(V) 8MP
  • Pixel Size: 1.12 µm (H) × 1.12 µm (V)
  • IR Sensitivity: Visible light
  • Interface: 2-lane MIPI CSI-2
  • Default Lens Mount: M12 Mount Lens(PN#M32076M20)
  • Video Modes: RAW8/RAW10
  • Resolution and Frame Rate: 8MP@21fps, 1080p@30fps, 720p@120fps
  • Board Size: 24mm x 24mm
- Lens
  • Format: 1/4 inch
  • Focal Length: 0.76mm
  • Aperture (F): F2.1
  • Field of View (FOV): 220° (H)
  • Mount: M12 Mount
  • Back Focal Length: 2mm
  • MOD: 0.2m
  • Dimension: Φ16×13.5mm
  • Weight: 5g
Camarray – Arducam 8MP IMX219 Synchronized Stereo Camera Bundle Kit
Introduction ​This Arducam 8MP Synchronized Stereo Camera Bundle Kit is capable of running two 8MP IMX219 Camera Modules simultaneously through a single MIPI CSI-2 camera slot connection on Jetson Nano/Xavier NX. The stereo camera HAT is enabled by ArduChip to disguise the dual-camera connection as a single camera to be accepted by the single-board computers. […]
arducam jetson nano camera general purpose solution blog thumbnail 215 187
Introducing Project Jetvariety – Increase the Jetson Nano Camera Variety Today we are proud to introduce the Project Jetvariety (short for Jetson variety), which aims to quickly increase the variety of Jetson Nano cameras with our proprietary general-purpose camera solution. The Jetson Nano and Xavier NX only have official driver support of the Raspberry Pi […]
16 comments
Package Includes
  • 1pcs Arducam Synchronized Stereo Camera HAT for Jetson Nano/Xavier NX With Fisheye Lens
  • 2pcs 8MP IMX219 color camera module mounted with M12 lens
  • 2pcs Arducam 73mm 15pin to 22pin Ribbon Cable
  • 1pcs Arducam 150mm 15pin to 22pin Ribbon Cable
NOTE 1:
Jetson Nano board is not included in the package.
NOTE 2:
The IMX219 cameras in this kit is a special version and cannot be used on Raspberry Pi or Jetson directly. Its connection to the Camarray HAT is required.
NOTE 3:
This kit is released for official Jetson Nano/Xavier NX boards by default, and it does not support other third-party boards.
NOTE 4:
8MP IMX219 Synchronized Stereo Camera Bundle Kit supports the official IMX219 driver The official driver has good image effect, but does not support full spelling.
The official driver supports official commands, can use the official ISP, has AWB, AE and other functions, the image effect is nice.
However, it does not support full spelling, it is compressed half spelling (to ensure the same resolution after compositing, the resolution of each camera is compressed in the horizontal direction by half, but the field of view remains the same).
NOTE 5:
  2. The Camarray HAT requires different firmware for different Image sensors that are not natively working with your embedded systems. Your own IMX219 camera modules won’t directly work with it, and they are not easily interchangeable.
