1.2MP Global Shutter USB Camera Evaluation Kit - CMOS AR0135 1/3-Inch Color Camera Module with USB2 Camera Shield-Arducam
Arducam OV9281 1MP Global Shutter USB Camera Evaluation Kit - 1/4-inch Monochrome M12 NoIR Camera Module with USB3.0 Camera Shield Plus
Arducam 2.3MP AR0234 Color Global Shutter Camera USB2.0 Evaluation Kit
EK031
  • Highly Integrated: Support MIPI interface without any MIPI adapter board
  • Color Global Shutter: 2.3MP AR0234 Color Global shutter sensor
  • General Solution: Compatible with any hardware you choose
  • Developer-friendly SDK & API for easy integration
$179.99
Arducam AR0234 Color Global Shutter Camera eliminates rolling shutter artifacts to better capture fast-moving objects. This camera can be used for dynamic capture of high-speed moving objects, real-time monitoring of factory machines, etc.
The highlight of the new USB2.0 camera shield is that it supports MIPI interface sensors without any MIPI adapter board. It has an onboard 16MByte hardware frame buffer, and overcomes the bandwidth and dropping frames issue when using the software frame buffer scheme.
  • Cellular phones
  • Toys
  • Tablets
  • Machine vision
  • ARM/FPGA/DSP based platforms
  • Product prototyping/development, etc.
    About External Trigger Mode: This camera module supports the development of external trigger mode function. If you have relevant requirements, please contact Arducam sales for customization.
Specs
Resolution/Frame Rate* 960x600@80fps, 1920x1200@20fps
Sesnor Output Format 34us-33333us
Exposure Control Range 34us-33333us
Gain Control Range 2.0-11.0 Times
Focus Control Range /
Focal Length 3.6mm
Field of View(FOV) 120°(D)x90°(H)x75°(V)
F.NO 2.8
Power Consumption* 5V/300mA
Operation Temperature -10℃~+55℃
Evaluation Kit Size 40mm x 40mm
Functions
Image File Format DNG/JPEG
External Trigger Mode Not Supported
Software ISP Not Supported
Supported Programming Languages Python/C++
Supported OS Windows x86/x86_64
GUI(Graphical User Interface) Supported
Optional Items
Random Resolution These addtional functions require customized serivces to get supported. Please contact [email protected] for customization services.
Even Higher/Lower Frame Rate
More RAW Output Format Options(RAW10)
Long Exposure
  • 1 x Arducam USB2 Camera Shield - Support MIPI Interface Sensors
  • 1 x Arducam 2.3MP AR0234 Camera Module with M12 lens
  • 1 x 500mm USB2.0 micro-USB Cable
  • 1 x 80mm 22pin 0.5mm pitch FPC cable
FAQ
Does it support other image formats?
- With post-processing from the software side, yes.
Can I use it with Raspberry Pi & Jetson Nano?
- Yes, but we highly recommend using our high-res Pi/Jetson camera series.
Can I use custom resolutions & frame rates?
- Yes.
Does it support H.264/H.265 encoding?
-It depends on the hardware you are using the camera kit with.
