The AR0135 module is a 1/3 inch 1.2MP global shutter Color camera module which can be operated in its default mode or programmed for frame size, exposure, gain, and other parameters. The default mode output is a full-resolution image at 30 frames per second (fps). It outputs 8-bit raw data, using either the parallel output ports. The device may be operated in video (master) mode or in frame trigger mode.
High frame rate, high dynamic range, great sensitivity for machine vision with external trigger.
| Specs | |
| Resolution/Frame Rate* | 1280x964@30fps |
| Sesnor Output Format | RAW8 |
| Exposure Control Range | 34us - 33333us |
| Gain Control Range | 0.0-3.0 times |
| Focus Control Range | N/A |
| Focal Length | 2.8mm |
| Field of View(FOV) | 103°(D)x95°(H)x63°(V) |
| F.NO | 2.8 |
| Focus Type | Manual Focus |
| Power Consumption* | / |
| Operation Temperature | 0-50 ℃ |
| Evaluation Kit Size | 40mmx40mm |
| Functions | |
| Image File Format | No support |
| External Trigger Mode | Support |
| Software ISP | No support |
| Supported Programming Languages | Python/C++ |
| Supported OS | Windows x86/x86_64 |
| GUI(Graphical User Interface) | Supported |
| Optional Items | |
| Random Resolution | These addtional functions require customized serivces to get supported. Please contact [email protected] for customization services. |
| Even Higher/Lower Frame Rate | |
| More RAW Output Format Options(RAW10) | |
| Long Exposure | |
| External Trigger Mode | |
Introduction Arducam AR0134/AR0135 camera breakout incorporates ON Semiconductor 1/3-inch 1.2 Mp CMOS digital image sensor with an active-pixel array of 1280 (H) × 960 (V).It can support 1.2 megapixel (1280H x 960V) digital still images and a 720p (1280H x 720V) digital video mode. It is designed for low light performance and features a global […]
Arducam Camera Evaluation Kit - Windows Driver Installation
Arducam Camera Evaluation Kit - SDK&API
