Arducam 2.3MP AR0234 Color Global Shutter Camera USB2.0 Evaluation Kit
Arducam 9MP USB Camera Evaluation Kit - CMOS MT9N001 1/2.3-Inch Color Camera Module with USB2 Camera Shield
Arducam OV9281 1MP Global Shutter USB Camera Evaluation Kit - 1/4-inch Monochrome M12 NoIR Camera Module with USB3.0 Camera Shield Plus
EK026
  • Note: The Camera Evaluation Kit needs a configuration file (sent via shipping notice) and isn’t plug-and-play.
  • $231.99
    The Arducam monochrome (B&W) global shutter 1280x800 resolution OV9281 MIPI camera module is mainly designed for Raspberry Pi boards, and it can be connected directly to RPi’s CSI-2 camera interface without additional hardware. This camera is based on 1/4-inch Omnivision OV9281 image sensor which adopts OmniPixel3-GS™ technology to provide full-frame, sub-sampled, and windowed 8/10-bit MIPI images, and capable of operating at up to 60fps in full resolution at 1lane MIPI bus with complete user control over image quality.
    The sensor's global shutter and excellent low-light sensitivity allow it to be used for any application that needs gesture detection, head and eye tracking, and depth and motion detection.
    • Sensor: Monochrome global shutter OV9281
    • Pixel Size: 3 μm x 3 μm
    • Active array size: 1280 x 800
    • Optical Size: 1/4 inch
    • Focusing Range: 30mm ~ infinite
    • Output interface: 2-lane MIPI serial output
    • Output formats: 8/10-bit BW RAW
    • Maximum image transfer rate: 1280 x 800@120 fps
    • Board Size: 40mm x 40mm
    • Lens: Default: low distortion M12 lens (Part Number: M27280M07S)
    • EFL: 2.8, F.NO: 2.8, HFOV: 70 Deg.
    • IR Sensitivity:sensitive to IR, No IR filter
    • Security
    • High dynamic range imaging
    • Unattended surveillance
    • Stereo vision
    • Machine vision
    • Automation
    Documentation:
    OV9281 1MP Global Shutter Camera for Raspberry Pi
    Introduction The Arducam OV9281 camera breakout incorporates Omnivision 1/4-inch 1 Mp  (1280×800) CMOS digital image sensor which is capable of operating at up to 60fps in 1MP ( 1280×800 ) resolution at 1-lane MIPI mode. The OV9281’s high frame rates make it an ideal solution for low-latency machine vision applications. The global shutter technology allows […]
    Posts not found
    Arducam USB Camera Shields
    Arducam Camera Evaluation Kit - Windows Driver Installation
    Arducam Camera Evaluation Kit - SDK&API
    GitHub:
    ArduCAM_USB_Camera_Shield
    Package Including:
    • 1 pcs Arducam OV9281 USB3.0 Camera Evaluation Kit with Back Cover
    • 1 pcs USB3.0 Cable
