Arducam 1/4
Arducam 1/4" 3 Mega pixel M12 Mount OV3640 Camera Module with JPEG Output
Arducam 2MP OV2640 1/4” Camera Breakout Board
[Discontinued] Arducam 1.2MP AR0135 Mono 1/3" CMOS Camera Module
B0124
AR0135 Mono.
Global shutter.
High frame rate, high dynamic range, good sensitivity for machine vision with external trigger
$99.99
The AR0135 module is a 1/3 inch 1.2MP global shutter Monochrome camera module which can be operated in its default mode or programmed for frame size, exposure, gain, and other parameters. The default mode output is a full-resolution image at 54 frames per second (fps). It outputs 12-bit raw data, using either the parallel output ports. The device may be operated in video (master) mode or in frame trigger mode.High frame rate, high dynamic range, good sensitivity for machine vision with external trigger.
  • 1/3" optical format
  • 1.2MP 1280 x 960 AR0135 global shutter sensor
  • 3.75 x 3.75um Pixel size
  • 54fps at full resolution
  • 5.3V/lux-sec responsivity
  • 64dB dynamic range
  • single 3.3V power input
  • Parallel camera interface
  • Default M12 mount 6mm LS-6020 lens
  • Security
  • High dynamic range imaging
  • Unattended surveillance
  • Stereo vision
  • Machine vision
  • Automation
  • 1 pcs Arducam CMOS AR0135 1/3-Inch 1.2MP Monochrome Camera Module
  • NOTE: The camera module only can be used together with Arducam USB shield
User guide.pdf
Arducam USB3.0 Camera Shield
Github
ArduCAM/RaspberryPi
