[Discontinued] Arducam NoIR IMX219-AF Programmable/Auto Focus IR Sensitive Camera Module for NVIDIA Jetson Nano/Xavier NX
[Discontinued] Arducam 2MP OV2640 Color 1/4” Camera Module with LS-4011 M12 Mount lens
Arducam 2MP OV2640 1/4” Camera Breakout Board
OV2640
Recommending Reading: OV2640 Full Report – Specs, Cameras, Features, and Alternatives
  • We also have the OV2640 SPI module if you want to use this on Arduino UNO boards, MCU, ARM, DSP and FPGA platforms.
  • M12/CS mount lens holder with changeable lens options.
  • Decent low light performance (details can be found below).
  • Low power consumption
$1.00
ov2640 thumbnail
OV2640 – Specs, Datasheets, Cameras, Features, Alternatives
OV2640, an evergreen image sensor from OmniVision. It was released in 2005 and discontinued in 2009, yet still used a lot in today’s products. While this image sensor remains popular, there are also uncertainties ahead. You may have questions like the followings: What’s good about it?  What makes it so popular?  How to deal with […]
3 comments
Application
  • Cellular phones
  • PDAs
  • Toys
  • Can be used in MCU, Raspberry Pi, ARM, DSP, FPGA platforms
  • Flex type module or M12 mount lens holder with more lens options module
  • 1/4” sensor size
  • High sensitivity for low-light operation
  • Standard SCCB interface
  • Output support for Raw RGB, RGB (RGB565/555), GRB422, YUV (422/420) and YCbCr (4:2:2) formats, JPEG compression formats
  • Supports image sizes: UXGA, SXGA, SVGA, and any size scaling down from SXGA to 40×30
  • Automatic image control functions including Automatic Exposure Control (AEC), Automatic Gain Control (AGC), Automatic White Balance (AWB), Automatic Band Filter (ABF), and Automatic Black-Level Calibration (ABLC)
  • Image quality controls including color saturation, gamma, sharpness (edge enhancement), lens correction, white pixel canceling, noise-canceling, and 50/60 Hz luminance detection
  • Low operating voltage for embedded portable apps
Datasheets
Pin Definition
1 VCC POWER 3.3v Power supply
2 GND Ground Power ground
3 SCL Input Two-Wire Serial Interface Clock
4 SDATA Bi-directional Two-Wire Serial Interface Data I/O
5 VSYNC Output Active High: Frame Valid; indicates active frame
6 HREF Output Active High: Line/Data Valid; indicates active pixels
7 PCLK Output Pixel Clock output from the sensor
8 XCLK Input Master Clock into Sensor
9 DOUT9 Output Pixel Data Output 9 (MSB)
10 DOUT8 Output Pixel Data Output 8
11 DOUT7 Output Pixel Data Output 7
12 DOUT6 Output Pixel Data Output 6
13 DOUT5 Output Pixel Data Output 5
14 DOUT4 Output Pixel Data Output 4
15 DOUT3 Output Pixel Data Output 3
16 DOUT2 Output Pixel Data Output 2 (LSB)
17 DOUT1 Output Pixel Data Output 1(10bit mode)
18 DOUT0 Output Pixel Data Output 0 (10bit mode)
19 RST Input Camera reset, active low
20 PWDN Input Camera power down, active high
Demonstration
ArduCAM provides a full demonstration for the OV2640 camera module on the Arduino platform. Please download the examples from Github.
Example ArduCAM_Shield_V2_Camera_Playback.ino
It will turn the ArduCAM into a real digital camera with capture and playback functions.
1. Preview the live video on LCD Screen.
2. Capture and buffer the image to FIFO when the shutter pressed quickly.
3. Store the image to Micro SD/TF card with BMP format.
4. Playback the capture photos one by one when the shutter button holds on for 3 seconds.
This program requires the latest ArduCAM library and ArduCAM Shield_V2 ArduCAM shield and use Arduino IDE 1.6.8 compiler or above.
Example ArduCAM_Shield_V2_Digital_Camera.ino
It will run the ArduCAM as a real 2MP digital camera, provide both preview and JPEG capture
The demo sketch will do the following tasks:
1. Set the sensor to BMP preview output mode.
2. Switch to JPEG mode when the shutter button pressed.
3. Capture and buffer the image to FIFO.
4. Store the image to Micro SD/TF card with JPEG format.
5. Resolution can be changed by myCAM.OV2640_set_JPEG_size() function.
Example ArduCAM_Mini_Video_Streaming.ino
1. Set the sensor to JPEG output mode.
2. Capture and buffer the image to FIFO.
3. Transfer the captured JPEG image back to host via Arduino board USB port.
4. Resolution can be changed by myCAM.OV2640_set_JPEG_size() function.
This program requires the latest ArduCAM library and Rev.C or Rev.C+ ArduCAM shield and use Arduino IDE 1.6.8 compiler or above.
5. Use ArduCAM host v2 application to capture, view and save pictures.
Sample Pictures Taken by OV2640
OV2640 UXGA 1600x1200 - Arducam Based Camera
2_gen_arducam_shield_blog_thumbnail
Second Generation ArduCAM Shields and Modules
Introduction ArduCAM series camera shield is a universal camera control board for Arduino. It hides the complex nature of the camera and provides the plug and play camera control interface as well as the ready to use software source code library and demo code. User can make it works in minutes without writing a line […]
1 comment
ov2640_manual_exposure_blog_thumbnail
Manual Exposure for OV2640
Overview ArduCAM all given examples are using auto exposure for easy use of the camera. But somethings users want to control the exposure more precisely. This article will cover how to do manually exposure to OV2640 camera.
2MP OV2640
Introduction Arducam OV2640 camera breakout incorporates Omnivision 1/4−inch CMOS active−pixel digital imaging sensor OV2640 with an active pixel array of 1632 x 1232 including border pixels. The entire system-on-a-chip (SOC) has low power requirements that is particularly suitable for IoT applications. It has onchip AEC/AGC/AWB ISP functions, and supports RAW/YUV/RGB/JPEG different output format. Key Specification […]
Software Guide
Introduction This page describle the basic control over the sensor registers using Arducam camera breakout board, it might not be able to cover all the detail register operations, but give you an insight how to adjust these settings. Sensor I2C Slave Address The OV2640 camera I2C 8-bit slave address is fixed to 0x60. With 8bit […]
Hardware Guide
Introduction This hardware guid helps for interfacing the Arducam OV2640 camera module. There are hardware USB2 or USB3(you also need Arducam Parallel Camera Adapter Board for USB3)camera shield develop boards which can well mate this camera module without designing any customize board, they can be used for fast evaluation for this camera module. Pin Definition […]
