New Spy Camera for Raspberry Pi
  • Introduction
In order to meet the increasing need of Raspberry Pi compatible camera modules. The ArduCAM team now released another add-on spy camera module for Raspberry Pi series boards which is fully compatible with official one.
The board itself is tiny, at around 300mm x 16mm. The neck width of the camera module is 6mm, this highlight making it perfect for endoscope, spy surveillance or other applications where size and image quality are important.
It connects to Raspberry Pi by way of a short ribbon cable. The camera is connected to the BCM2835/BCM2836 processor on the Pi via the CSI bus, a higher bandwidth link which carries pixel data from the camera back to the processor. This bus travels along the ribbon cable that attaches the camera board to the Pi.
It attaches to Raspberry Pi by way of one of the two small sockets on the board upper surface. This interface uses the dedicated CSI interface, which was designed especially for interfacing to cameras. The CSI bus is capable of extremely high data rates, and it exclusively carries pixel data. The camera is supported in the latest version of Raspbian, Raspberry Pi’s preferred operating system.
  • Features
  • High-Definition video camera for Raspberry Pi Model A/B/B+ and Raspberry Pi 2
  • 5MPixel sensor with Omnivision OV5647 sensor in a fixed-focus lens
  • Integral IR filter
  • Angle of View: 54 x 41 degrees
  • Field of View: 2.0 x 1.33 m at 2 m
  • Full-frame SLR lens equivalent: 35 mm
  • Fixed Focus: 1 m to infinity
  • Still picture resolution: 2592 x 1944
  • Max video resolution: 1080p
  • Max frame rate: 30fps
  • Size: 300 x 16 mm flex cable, neck wide is 6mm
  • Mechanical Dimension
SpyPiCAM6
Leave a Reply
