Arducam MIPI Adapter Board for USB3 Camera Shield
[Discontinued] Arducam USB2 Camera Shield
Arducam USB3.0 Camera Shield
B0111
ArduCAM USB3.0 Camera Shield is discontinued.
Please check the upgrade version B0317 Here.
$99.99
Arducam USB3 camera shield is the latest USB3.0 camera shields, it offers improved performance and enhanced functions than the previous USB2.0 camera shield. It not only supports high resolution and high frame rate image sensors but also supports stereoscopy camera and IRCUT control features. With the given camera configuration files, users can switch between different cameras without any effort. It is the ideal solution for camera evaluation/testing, robot/drone, IoT, machine vision and scientific applications.
  • Support any parallel image sensors (need proper register settings)
  • Support 8/10/12/14/16 bit pixel color depth
  • Support Stereoscopy mode for the dual-camera system
  • Build-in IRCUT control (optional)
  • Need extra MIPI to parallel adapter board for supporting MIPI interface sensors (see Table1)
  • Fully customizable and can be ported to any hardware platform and software OS (Current SDK Version Supports Windows Only)
  • Bandwidth: 5-Gbps USB3.0 PHY
  • Camera Databus: 16bit@100MHz
  • I/O Voltage Standard: 3.3V
  • Connector: Micro-USB3.0
  • Size: 40 x 40 mm
  • Weight: 10g
  • Power Consumption: 5V/300mA
  • Mating Connectors:
    - M50-4912045 (1.27mm board to board connector male pins)
    - M50-4302045 (1.27mm board to board connector female sockets)
Table 1 Featured Camera Modules Supported
Resolution Frame Rate Camera Module Sensor Vendor
0.3MP 100fps OV7251 (MIPI) Omnivision
0.3MP 60fps MT9V022/MT9V034 Aptina
1.3MP 50fps AR0134/AR0135 Aptina
5MP 15fps OV5647 (MIPI) Omnivision
9MP 7fps MT9N001 Aptina
10MP 6fps MT9J001/MT9J003 Aptina
14MP 5fps MT9F002 Aptina
13MP 5fps OV13850 (MIPI) Omnivision
  • 1 pcs ArduCAM USB3.0 Camera Shield
  • 1 pcs USB3.0 Cable
NOTE:
  • Camera module/breakout is not included, should order separately.
Documentation:
Arducam USB Camera Shields
User guide.pdf
3D drawing.step
GitHub
ArduCAM/ArduCAM_USB_Camera_Shield
