Arducam USB3.0 Camera Shield
[Discontinued] Arducam 1.2MP AR0135 Color 1/3
[Discontinued] Arducam 1.2MP AR0135 Color 1/3" CMOS Camera Module
[Discontinued] Arducam USB2 Camera Shield
B0095
$49.99
The second generation of Arducam USB2.0 shield is designed to replace the old one released in March 2017 while keeping the same form of factor and software compatible. The highlight of the new USB2.0 camera shield is that it has onboard 8MByte hardware frame buffer, and overcome the bandwidth and dropping frames issue when using the software frame buffer scheme. In addition, with the onboard frame buffer, it supports synchronized multiple cameras taking images exactly at the same time. Now it well supports both PC and an embedded system like Raspberry Pi, and also can provide customized support for Odroid, Beaglebone Black, Nvidia JETSON TK/TX boards.
  • Support any parallel image sensors
  • Support 8/10/12 bit pixel color depth
  • Build-in IRCUT control (optional)
  • Need extra MIPI to parallel adapter board for supporting MIPI interface sensors
  • Support x86, ARM 32/64bit hardware platforms
  • Support Windows, Linux OS
  • Bandwidth:480Mbps USB2.0
  • I/O Voltage Standard: 3.3V
  • Connector: Micro-USB2.0
  • Onboard Frame Buffer 8MBytes
  • Size: 40 x 40 mm
  • Weight: 20g
  • Power Consumption: 5V/300mA
Supported Camera Modules
Please check this page for the featured supported cameras of the Arducam USB2.0 camera shield.
  • 1 pcs USB2.0 micro-USB Cable
NOTE
  • Camera module/breakout is not included, should order separately.
Arducam USB Camera Shields
User guide.pdf
GitHub
ArduCAM/ArduCAM_USB_Camera_Shield
2_gen_usb2_camera_shield_blog_thumbnail
Second Generation ArduCAM USB2.0 Camera Shield
The second generation of Arducam USB2.0 shield is designed to replace the old one released on March 2017 while keeping the same form of factor and software compatible. The highlight of the new USB2.0 camera shield is that it has onboard 8MByte hardware frame buffer, and overcome the bandwidth and dropping frames issue when using […]
