[Discontinued] 1080P Low Light Low Distortion USB Camera Module with Microphone, 2MP IMX323 Mini Webcam
[Discontinued] Arducam IMX219 Low Distortion IR Sensitive (NoIR) M12 Mount Camera Module for NVIDIA Jetson Board
[Discontinued] Arducam 8MP Synchronized Stereo Camera Bundle Kit for Raspberry Pi
B0195S8MP
  • Discontinued, check the alternative item B0396
  • This bundle includes an Arducam stereo camera HAT, an 8MP IMX219 stereo camera board, and ribbon cables to connect them.
  • The stereo camera HAT allows you to use two Raspberry Pi cameras simultaneously on a single CSI-2 slot.
  • Check Jetson Nano version SKU: B0217J8
  • The stereo camera board frees you of any soldering in setting up your stereo vision with two Raspberry Pi camera module V2.
$129.99
Now Arducam released a stereo camera HAT for Raspberry Pi which allows you to connect two 5MP OV5647 or two 8MP IMX219 pi cameras to a single standard pi board, and takes images or video at the same time, even more, important they are fully synchronized. The highlight of this stereo camera HAT is that it incorporates Arducam proprietary ArduChip solution, and extends the usage of the single pi camera port, it cheats the Raspberry pi as if only one camera connected. It supports libcamera apps for previewing and video capture/processing with Rpi default camera driver for its 5MP and 8MP cameras. It also supports other Arducam Raspberry Pi cameras and a proprietary camera driver that works up to two 16MP. With the shared oscillator and I2C broadcasting, the two cameras are fully synchronized in the nano-second level. With the latest new coming Pi 4 hardware, Arducam makes more camera applications possible for Raspberry Pi.
  • Support all series Raspberry Pi boards, Pi HAT board style
  • Support 1, 2 and 4 lane MIPI cameras input up-to 800Mbps/lane
  • Support 2 lane MIPI output
  • Support libcamera apps to preview and capture videos for 5MP/8MP pi cameras with half-resolution combine
  • Support Arducam RPI cameras up to 16MP with proprietary camera driver with full resolution combine
  • Support digital pan in half resolution combine, programmable pan speed control
  • Board size: 65 x 56 mm
  • Weight: 16 g
  • Focus distance: 200mm ~ infinity
  • Stereo Vision
  • 360 Camera
  • Advanced Surveillance Camera
Package Includes
  • 1pcs Arducam Synchronized Stereo Camera HAT for Raspberry Pi
  • 1pcs 8MP Arducam Stereo Camera Board
  • 3pcs Arducam 80mm 22pin Ribbon FPC flat Wire Cable
  • 1pcs Arducam 73mm 15pin to 22pin Ribbon FPC flat Wire Cable
  • 4pcs M2.5*11mm Nylon Hex Standoffs
  • 4pcs M2.5 Nylon Nuts
  • 3pcs M2.5*6mm Nylon Screws
NOTE
  • Oscillator sharing requires extra cables, soldering skill needed or please use Arducam bundle kit
  • Contact us for other platform support
  • This camera module supports the latest Raspberry Pi OS Bullseye (released on Jan 28th, 2022) and libcamera apps, for the previous Raspberry Pi OS (Legacy) users, contact us at [email protected].
synchronized-stereo-pi-camera-hat-dual-blog-thumbnail
58 comments
3D drawing.step
3D drawing.step
Camarray – Arducam 8MP Synchronized Stereo Camera Bundle Kit
Introduction ​This Arducam 8MP Synchronized Stereo Camera Bundle Kit is capable of running two 8MP IMX219 Camera Modules simultaneously through a single MIPI CSI-2 camera slot connection on Raspberry Pi. The stereo camera HAT is enabled by ArduChip to disguise the dual-camera connection as a single camera to be accepted by the single-board computers. You […]
