[Discontinued] Arducam 5MP OV5647 Camera Module with M12x0.5 Lens for Raspberry Pi 5, 4/3B+/3 (NoIR)
Arducam 8MP IMX219 USB2.0 Camera Module with 300mm Extension Cable
[Discontinued] Arducam 14MP MT9F002 Color 1/2.3‘’ CMOS Camera Module
B0097
Discontinued, Check Arducam USB Evaluation Kit
14MP MT9F001 MT9F002 Color 1/2.3″ CMOS.
World-Class 1.4μm Pixel Sensitivity.
Perfect for DSC/DVC designs.
$64.99
The MT9F001/002 camera module features Aptina’s breakthrough low-noise CMOS imaging technology that achieves near-CCD image quality (based on signal-to-noise ratio and low-light sensitivity) while maintaining the inherent size, cost, and integration advantages of CMOS. 1/2.3" 14MP (4608 x 3288) CMOS color rolling shutter with global reset release camera module MT9F001/002. World-Class 1.4μm Pixel Sensitivity, Produced on Aptina’s world-class 1.4μm pixel with Aptina A-Pix technology, this high-resolution, highly sensitive compact sensor is perfect for DSC/DVC designs.
Full HD Video Modes and EIS, Full HD support—1080p at 60 fps—for max video performance and 20% extra imaging area for image stabilization.
Improved Low Light Performance Equivalent level as CCD sensor to support DSC applications.
Preprocessing Features, including resampling for sub-sampled video and 2D defect correction, provide improved image quality.
  • 1/2.3" optical format
  • RGB Bayer pattern
  • 14MP 4608 x 3288 MT9F001/002 sensor
  • 1.4 x 1.4 um Pixel size
  • 6.3fps at full resolution
  • 0.724V/lux-sec responsivity
  • 65.3dB dynamic range
  • single 3.3V power input
  • Parallel camera interface
  • Default M12 mount 4.2mm LS-18023 lens
  • Digital video cameras
  • Digital still cameras
  • Industrial camera
  • Medical camera
  • Microscopy camera
  • UAV camera
Package includes
  • 1pcs Arducam CMOS MT9F001 1/2.3-Inch 14MP Color Camera Module
NOTE: The camera module only can be used together with the Arducam USB shield.  You could check USB shield here:
Arducam USB2.0 Shield
Arducam USB3.0 Shield
14MP MT9F001/MT9F002
Introduction Arducam MT9F001/MT9F002 camera breakout incorporates ON Semiconductor 1/2.3−inch CMOS active−pixel digital imaging sensor MT9F001/MT9F002 with an active pixel array of 4608 H × 3288 V (4640 H × 3320 V including border pixels). It can support 14−megapixel (4384 H × 3288 V) digital still images and a 1080p plus additional 20 percent pixels for […]
Instruction Manual.pdf
Arducam USB3.0 Camera Shield
GitHub
ArduCAM/RaspberryPi
