[Discontinued] Arducam 3MP AR0330 1/3
[Discontinued] Arducam 3MP AR0330 1/3" SENSOR Standalone Camera UC0330-D46
[Discontinued] Arducam 14MP MT9F002 Color 1/2.3‘’ CMOS Camera Module
[Discontinued] Arducam 5MP OV5647 Camera Module with M12x0.5 Lens for Raspberry Pi 5, 4/3B+/3 (NoIR)
B0035
Discontinued, check alternative item B0151
  • IR Sensitivity: NOIR
  • High-Definition video camera for Raspberry Pi Model A or B, B+, model 2, Raspberry Pi 5,3,3b+
  • OmniVision OV5647 sensor in a fixed-focus module with replaceable Lense
  • Connection by a flat ribbon cable to 15-pin MIPI Camera Serial Interface (CSI) connector S5 on Raspberry Pi computer board
was $29.99 Special Price $19.99
The Raspberry Pi camera module has been used for many things such as a security camera, for time-lapse photography and even sent high up into the atmosphere on a weather balloon.
With the wide range of the project, Raspberry Pi’s are being used for, some users were finding that the camera was no good when it was being used in low light with an Infrared light source. Unfortunately for them, the Raspberry Pi camera module has an Infrared filter built in which makes it unusable for their project. In response, we come up with a camera module just for these types of projects called the Pi NoIR camera. It is the same as the standard camera module but without an IR filter.
Without the Infrared filter, the camera can be used for night time photography, night time security or for any project where the scene will be lit by an IR light. Without a filter, the camera sensor can see short wavelength IR light around 800nm which is the IR wavelengths not generated with heat but just beyond the visible red light in the spectrum.
The camera has the same specifications as the standard camera module but has a black circuit board so it can be told apart from the standard green camera board.
  • Home security
  • Science project
  • Robot cameras
  • Wildlife cameras
  • Night/Low Light photograph
  • Making artist photo, etc.
Sensor size 1/4” (OV5647)
Resolution 5MP 2592×1944
IR Sensitivity NOIR
Horizontal Field of View (HFOV) 110°(H)
Focus Type Manual
Lens Type M12 Lens
Dimension 36mm x 36mm
Peak Current 300mA
  • 1 x OV5647 NoIR Camera Board /w M12x0.5 mount for Raspberry Pi
  • 1 x 15cm 15-15pin FPC cable
  • 1 x 15cm 15-22pin FPC cable
  • Visit www.ArduCAM.com for more wide angle fish eye lenses and get technical support
  • The Camera Lens for Raspberry Pi Camera Board is LS1820 FOV: 110 ° (H)
    Raspberry Pi 5
OV5647 NoIR Camera for Raspberry Pi Now Released
  The Pi NoIR is a Raspberry Pi camera module with no Infrared filter for night time and low light photography using an Infrared light. Useful for wildlife research, science projects, night time security or making artistic photo’s. The Raspberry Pi camera module has been used for many things such as a security camera, for time […]
1 comment
Selection Guide
Edit
