Arducam 8MP Motorized Focus 8MP Camera IMX219 Sensor for Raspberry Pi 4/3B+/3
0.3MP OV7251 1/7.5'' CMOS Global Shutter Standalone Camera UC-7251-716
Arducam 1MP OV9655 1/4" CMOS Standalone Camera Module UC9655-D
U6040
$4.20
  • Surveillance
  • Cellular and picture phones
  • Toys
  • PC multimedia
  • Digital still cameras
Details
  • High sensitivity for low-light operation
  • Low operating voltage for embedded portable apps
  • Standard SCCB interface
  • Output support for Raw RGB,RGB(GRB 4:2:2, RGB565/555), YUV (4:2:2) and YCbCr(4:2:2) formats
  • Supports image sizes:SXGA,VGA,CIF,and any size scaling down from CIF to 40*30
  • VarioPixel® method for sub-sampling
  • Automatic image control functions including automatic exposure control (AEC), automatic white balance (AWB), automatic band filter (ABF), and automatic black-level calibration(ABLC)
  • Image quality controls including color saturation, gamma, sharpness (edge enhancement), lens correction, white pixel canceling, noise canceling, and 50/60 Hz luminance detection
  • Supports LED and flash strobe mode
  • Supports scaling
    Key Specifications
    • Active array size: 1289*1024
    • Power supply: core 1.8VDC ± 10%, analog 2.45 to 3.0VDC,I/O 1.7V to 3.3V
    • Power requirements: active 90 mW typical (15fps SXGA YUV format), standby <20 uA, operation -30℃ to 70℃, stable image 0℃ to 50℃
    • Output formats (8-bit): YUV/YCbCr 4:2:2, RGB565/555, GRB 4:2:2, Raw RGB Data
    • Lens size: 1/4"
    • Chief ray angle: 25°
    • Maximum image transfer rate: SXGA 15fps, (VGA CIF and down scaling) 30fps
    • Sensitivity: 1.1V/(Lux• sec)
    • S/N ratio: 42 dB
    • Dynamic range: 50 dB
    • Scan mode: Progressive
    • Maximum exposure interval: 1050 * tROW
    • Gamma correction: programmable
    • Pixel size: 3.18 um * 3.18 um
    • Dark current: 15mV/s at 60℃
    • Well capacity: 10 Ke
    • Fixed pattern noise: <0.03% of VPEAK-TO-PEAK
    • Image area: 4.17 mm * 3.29 mm
    • Package dimensions: 5145 um * 6145 um
