[Discontinued] Arducam 5MP 1080p Pan Tilt Zoom PTZ Camera with Base for Raspberry Pi 4/3B+/3
Check alternative camera B0167B12
  • Real PTZ with servos for directional control and varifocal lens for optical zoom now comes to the Raspberry Pi
  • IR Cut Switch: Switchable IR Cut through software for your day/night vision
  • Make full use of the CSI connector now that a single camera can be used to monitor more place
  • Software Control: Autofocus control, pan/tilt/zoom keyboard control supported in software
  • Base on 5MP OV5647 1080P Camera board
  • PTZ Controller Board Connector Part Number: S6B-XH-A-1
This camera is a PTZ camera bundle kit based on the ov5647 sensor, we have made some changes on the basis of the sensor. PTZ is an abbreviation for pan, tilt, and zoom and reflects the movement options of the camera, and a pan–tilt–zoom camera (PTZ camera) is a camera that is capable of remote directional and zoom control. A PTZ camera is not a still camera. Instead, it could move the camera and the lens, and that means a single camera can be used to monitor places that should be covered by multiple ones. You can save a lot of cost and time in purchasing and deploying the camera if a PTZ camera can handle the job. With its moveable lens, you will also be able to zoom the camera to see a specific area that you are interested in. To conclude, it’s “do more with less.”
Application
  • IoT cameras
  • Robot cameras
  • Wildlife cameras
  • Sun Tracker
  • Other security and surveillance projects, etc.
SensorOmnivision OV5647 sensor
Sensor size1/4” (OV5647)
Resolution5MP 2592×1944
Video1080p 30 fps, 720p 60fps, 480p 90fps
Focal-Length3.2-11.1mm±5%
F No.W:1.6-T:3.3±5%
Focus TypeFront group: focus Back group: Zoom
M.O.D0.8m
Dimension36mm x 36mm
Pan and Tilt Range0-180°
Zoom Range (Wide => Tele)2317 steps 0.00396mm/step
Focus Range(Near => Far)3009 steps 0.0047mm/step
  • 1 x Arducam PTZ Pan Tilt Zoom Lens, assembled with a 5MP IR-CUT switchable camera board and a camera control board
  • 1 x 15-Pin FPC Cable (11.8 in/30 cm)
  • 1 x XH2.54 Jumper wire with 6Pin Female Connector (11.8 in/30 cm)
  • 1 x Base Alloy with servo
  • 1 x Black Acrylic Board
  • 12 x M3*10+6mm Nylon Standoffs
  • 8 x M3*6mm Nylon Screws
  • 8 x M3 Nuts
  • 4 x Copper standoffs for the base
  • Raspberry Pi board is not included in the package
Specification
1. 5MP OV5647 / 8MP IMX219 Camera No. Items Specification 1 F No. W:1.6-T:3.3±5% 2 Focal-Length 3.2-11.1mm±5% 3 Optical Back Focal Length 5.8±0.1 4 Mechanical Back Focal Length 13.45±0.2 5 TTL 52.14±0.2 6 Image Circle ∅6.9 7 Lens Structure 6G3P 8 Mount ∅14 9 FOV 1/2.7”(16:9): H(113~30),V(60~16),D(137~34) 1/3”(4:3): H(91~25),V(66~18),D(120~30) 1/4”(4:3): H(67~18),V(49~13),D(90~22) 10 M.O.D 0.8m 11 […]
How to use Arducam PTZ Camera with OctoPi to monitor 3D printers
Why add a camera to your 3D printers? Most 3D models take more than a few hours to print, so you may wish to leave the 3D printer at some point in the printing process. Using an Arducam camera to monitor 3D printing can make you pay close attention to your creation. Since most cameras […]
Pan Tilt Camera
OV5647
5MP
PTZ Cam
