- Onboard LDO regulators for 2.8V and 1.8V
- Single 3.3V power input
- 2.54mm (0.1 inch) standard pin out
- active array size: 2592 x 1944
- power supply:
- core: 1.5VDC + 5% (internal regulator)
- analog: 2.6 ~ 3.0V
- I/O: 1.7 ~ 3.0V
- output formats :
- (8-bit): YUV(422/420) / YCbCr422,
- RGB565/555/444, CCIR656,
- 8-bit compression data,
- 8/10-bit raw RGB data
- lens size: 1/4″
- input clock frequency: 6 ~ 27 MHz
- shutter: rolling shutter
- maximum image transfer rate:
- 5 megapixel (2592×1944): 15 fps (and any size scaling down from 5 megapixel)
- 1080p (1920×1080): 30 fps
- 720p (1280×720): 60 fps
- VGA (640×480): 60 fps
- QVGA (320×240): 120 fps
- scan mode: progressive
- pixel size: 1.4 µm x 1.4 µm
- image area: 3673.6 µm x 2738.4 µm
- RAW,RGB,YUV,JPEG output support
- External 1/4 inch high quality M12x0.5 lens
- Lens Specification: sensor size: 1/2.7″; EFL:3.6mm; F/N:2.3±5%; BFL:6.9mm; HFOV: 56 degree
Note: If you would like to change the lens, please choose the lens from the M12 lens kit here:
SKU: LK001 Arducam M12 mount camera lens kit for Arduino and Raspberry Pi camera
SKU: LK002 Arducam Low Distortion M12 mount camera lens kit for Arduino and Raspberry Pi camera
Pin Out:
Application:
- image acquisition
- Enviornment monitor
- Inductrial cameramachine vision flow detection
- medical endoscope
- video telephone
- safety guard alarm system
- door bell camera and video door bell
- vehicle monitoring
- romote monitor and control
- digital image record
- 3D scanner printer
- intelligent toys
Package including:
- 1pcs 5 Mega pixel Camera Module OV5642
5MP OV5642
Introduction Arducam OV5642 camera breakout incorporates Omnivision 1/4−inch CMOS active−pixel digital imaging sensor OV5642 with an active pixel array of 2592×1944. The entire system-on-a-chip (SOC) has onchip AEC/AGC/AWB etc ISP functions, and supports RAW/YUV/RGB/JPEG different output format. Key Specification Optical format 1/4−inch (4:3) Full Resolution 2592 x 1944 Pixel size 1.4 x 1.4µm Color filter […]
New 5MP OV5642 Camera Module (support JPEG output)
Key specifications active array size: 2592 x 1944 power supply: core: 1.5VDC + 5% (internal regulator) analog: 2.6 ~ 3.0V I/O: 1.7 ~ 3.0V output formats : (8-bit): YUV(422/420) / YCbCr422, RGB565/555/444, CCIR656, 8-bit compression data, 8/10-bit raw RGB data lens size: 1/4″ input clock frequency: 6 ~ 27 MHz shutter: rolling shutter maximum image […]
