Time to enjoy a smooth upgrade for your 8MP IMX219 to the 12MP HQ camera, or relieve the stress from the bulky Raspberry Pi High-Quality Camera Module! This Arducam 12MP camera module for Raspberry Pi has the same camera board size and mounting holes as the Raspberry Pi Camera Module V2, so no major hardware modifications are needed to ditch your 8MP IMX219 and embrace Arducam. Space- and weight-constrained applications, such as drones, also benefit from this camera, because it keeps the same imager performance and same control commands as the official Raspberry Pi High-Quality Camera, while offering a much smaller size and lighter weight, as well as interchangeable M12 lenses.
Application
- UAV/Drones/FPV camera
- Machine Vision
- Robotics
- Face Recognition
- Defect Detection, etc.
| Still Resolution | 12.3 Megapixels |
| Video Modes | 2028 × 1080p50, 2028 × 1520p40 and 1332 × 990p120 |
| Sensor Resolution | 4056 x 3040 pixels |
| Sensor image area | 6.287mm x 4.712 mm (7.9mm diagonal) |
| Pixel Size | 1.55 µm x 1.55 µm |
| Optical Size | 1/2.3" |
| IR Sensitivity | Integral IR-cut Filter, visible light only |
| Supported Platform | Raspberry Pi 5/4B/3B+/3/2/CM3/CM4/CM5/Zero W/Zero 2 W |
| Focus Type | Manual Focus |
| Focal Length | 3.9mm |
| F.NO | F2.8 |
| Field of View(FOV) | 88°(D)×75°(H) |
| Lens Mount | M12 |
Electrical & Mechanical
| Camera Board Size | 25 × 24mm |
- 1 x 12.3MP color camera modulem with 3.9mm focal length M12 mount lens
- 1 x 150mm/5.9inch 15pin to 22pin FPC cable
- 1 x 150mm/5.9inch 22pin camera cable
- Raspberry Pi board is not included in the package
12MP IMX477 Standard Camera Module
Introduction Arducam IMX477 cameras support all Raspberry Pi camera models. Pi 4, Pi 3/3B+/3A+, CM3/3+, Pi Zero, and more. Unlike the official high quality camera has only one hole pitch, Arducam IMX477 cameras offer 3 hole pitches 29mm, 30mm, 34mm. compatible with standard industrial camera enclosure. What’s more, they have a 4-lane MIPI CSI-2 interface, more […]
Multi-Camera Adapter Board
1. Introduction This adapter board supports 5MP and 8MP since the old multi-camera adapter board doesn’t work with Raspberry Pi 8MP IMX219 pi camera due to the camera driver issue. Now Arducam team designed upgrade the multi-camera adapter board for both 5MP and 8MP pi cameras. Consider that the high speed CSI camera MIPI signal […]
Lens Options
| SKU | LN056 | LN031 | LN074 | ||||||||
Part No: | M17350H08 | M2025ZM02 | M231250H03 | M2306ZM13 | M23390H08 | M23356H09 | M23270H10 | M23325H12 | M23272M14 | M25156H18 | M27150H19 |
| Optical Format | 1/2.3' | 1/2.3' | 1/2.3'' | 1/2.3'' | 1/2.3'' | 1/2.3'' | 1/2.3'' | 1/2.3'' | 1/2.3'' | 1/2.3' | 1/2.3' |
| EFL(mm) | 35.00 | 25.00 | 12.50 | 6.00 | 3.90 | 3.56 | 2.70 | 3.25 | 2.27 | 1.56 | 1.50 |
| BFL(mm) | 5.50 | 5.20 | 2.11 | 7.56 | 4.49 | 5.92 | 4.97 | 4.10 | 3.01 | 4.30 | 5.19 |
| Construction | 5G | 6G | 6G+IR | 6G+IR | 6G+IR | 4G3P+IR | 5G2P+IR | 7G+IR | 8G+IR | 6G+IR | 9G+IR |
| F/NO | 3.0 | 2.0 | 2.35 | 2.0 | 2.8 | 2.5 | 2.8 | 2.2 | 2.5 | 2.0 | 1.8 |
| HFOV on 1/2.3‘’ Cam | 8° | 20° | 30° | 50° | 75° | 90° | 100° | 120° | 140° | 180° | 190° |
| IR filter | No IR filter | No IR filter | 650 IR filter | 650 IR filter | 650 IR filter | 650 IR filter | 650 IR filter | 650 IR filter | 650 IR filter | 650 IR filter | 650 IR filter |
| MOD | 0.35m | 0.20m | 0.30m | 0.30m | 0.30m | 0.20m | 0.30m | 0.30m | 0.20m | 0.20m | 0.30m |
Size(mm) | 22x 29.3 | 17 x 21 | 14 x 22.72 | 16x 16.41 | 14x 18.67 | 14x 16.3 | 16x 18.43 | 17x 19 | 17.2x 22 | 20x 17.3 | 24x 16.9 |
NOTE: The M12 Lens kit for the HQ/AR1820HS Camera module, please check LK003, 6 lenses are included.
NOTE: For the sample order, please order the lens you need to replace separately and Contact us in advance for customization if you would like to replace the lenses on the Camera board.
Understand the Raspberry Pi High Quality Camera with M12 Lens and Mount
Quick answer to M12 lens RPi HQ Camera You either: Buy a customized m12 lens IMX477 camera (RPI-CAM-V2 sized) or Use an M12-CS adapter with an IMX477-matching M12 lens. Find more details in the blog below. Interchangeable lenses officially introduced to Raspberry Pi cameras The Raspberry Pi is a versatile minicomputer for makers to build […]
