[Discontinued] 1080P HD Wide Angle WDR USB Camera Module, 2MP 1/2.7″ CMOS AR0230 100 Degree Mini UVC USB2.0 Webcam
Discontinued, check alternative item B0438
  • HD Resolution and WDR: This camera adopts the 2MP AR0230 Color COMS sensor with a 96dB wide dynamic range.
  • Wide Angle: High quality 100 degree wide view angle (diagonal) M12 lens with IR filter.
  • Frame Rates: H.264 25fps@1920 x 1080; MJPG 25fps@1920 x 1080; YUY2 25fps@640 x 360.
  • Plug&Play: UVC-compliant, support Windows XP/7/8/10, Linux, Mac OS and Andriod device with UVC, just connect the camera to PC, laptop or Raspberry Pi with the USB cable without extra drivers to be installed.
  • Applications: this tiny 32mmx32mm camera board can be installed in the most hidden and narrow position for a home video surveillance system, day&night low light vision camera system, dashcam or other machine vision application.
SKU: B0203 Categories: ,
Arducam B0203 is a new member of Arducam’s USB camera family. It’s a 2MP, based on the 1/2.7” AR0230 image sensor, UVC-compliant USB 2.0 camera.
No longer be anxious about installing the driver! The native UVC drivers of Windows, Linux, Mac, and Android shall be compatible with this camera so that it does not require extra drivers to be installed.
This 2MP AR0230 color CMOS sensor produces the camera with a 96dB wide dynamic range, which gives you clearer visual joy when the object is backlighted and is more suitable for home security systems, object tracking, etc.
Features & Specs
  • Sensor: 1/2.7” AR0230
  • Resolution: 2MP 1928H x 1080V
  • Data Format: MJPG/YUY2/H.264
  • Frame Rate: H.264 25fps@1920 x 1080; MJPG 25fps@1920 x 1080; YUY2 25fps@640 x 360.
  • Dynamic Range: Up to 96dB
  • Field of View (FOV): D= 100°
  • Lens Mount: M12
  • Focusing Range: 3.3ft (1M) to infinity
  • IR Sensitivity: Integral IR filter, visible light only
  • Functionality and Compatibility
  • Auto Controlled Features: Saturation, Contrast, Acutance, White balance, Exposure.
  • System Compatibility: Windows, Linux, Mac, and Android with UVC
Power
  • Power Supply: DC 5V
  • Working Current: MAX 300mA
Physical
  • Operating Temp.: -4°F~158°F (-20°C~+70°C).
  • Dimension: 32mmx32mm
  • Cable Length: 3.3ft (1M)
    Lens option
    SKULN001LN065LN002LN003LN011LN012LN013LN005LN055LN007
    Model No:M2516ZH01M2512ZH03M2508ZH02M2506ZH04M2504ZH05SM25360H06SM27280M07SM27210H08M27195H15M25170H12
    Optical Format1/2.5'' 1/2.5'' 1/2.5'' 1/2.5'' 1/2.5'' 1/2.5'' 1/2.7'' 1/2.7'' 1/2.7'' 1/2.5''
    EFL(mm)16128643.62.82.11.951.7
    BFL(mm)7.16.58.17.33.242.752.66.33.84.7
    Construction6G+IR6G+IR6G+IR6G+IR2G2P+IR2G2P+IR2G2P+IR6G+IR6G+IR6G+IR
    F/NO2.02.02.02.02.83.02.82.02.02.0
    FOV (D/H/V) on 1/2.7‘’ Cam25/22/1231/27/1548/42/2564/57/3480/72/4590/82/52103/95/63136/130/101158/155/136180/180/180
    FOV (D/H/V) on 1/2.8‘’ Cam23/20/1129/25/1445/40/2362/55/3378/70/4388/80/5098/90/59131/125/94154/150/129180/180/180
    FOV (D/H/V) on 1/2.9‘’ Cam20/18/1026/23/1343/38/2260/53/3276/68/4286/78/4993/85/55127/120/89149/145/121180/180/180
    IR filter650 IR filter650 IR filter650 IR filter650 IR filter650 IR filter650 IR filter650 IR filter650 IR filter650 IR filter650 IR filter
    MOD0.3m0.3m0.3m0.3m0.3m0.2m0.3m0.3m0.2m0.2m
    Size(mm)14 x 16.214 x 16.714 x 16.914 x 17.414 x 18.714 x 16.314 x 15.614 x 15.217.5 x 19.920 x 18.7
    NOTE: The M12 Lens kit for the USB Camera module, please check LK005, 10 lenses are included.
    NOTE: For the sample order, please order the lens you need to replace separately and Contact us in advance for customization if you would like to replace the lenses on the Camera board.
    • 1 × 2MP AR0230 USB 2.0 camera board
    • 1 × 3.3ft (1M) USB 2.0 cable
    x86 PC
    UVC USB Camera
    USB 2.0
    AR0230
    2MP
    HDR
