Discontinued, check alternative item B0283.
Arducam B0227 is a new arrival, which can move your camera in two dimensions with 180 degrees horizontal and 145 degrees vertical movements. The PTZ camera controller board outputs the PWM signals to drive the servo motors directly. Therefore, B0227 can be used to control your camera to monitor places that should be covered by multiple ones commonly in the surveillance system.
Digital Servo
PTZ Control Board
Used on Pi
Introduction Arducam 8MP IMX219 Motorized Focus Camera Modules are designed for you to control the focus via software, so you can see closer and see where you want to see. To learn more about autofocus with Raspberry Pi camera modules, we recommend you read Raspberry Pi Camera Autofocus: The Complete Guide. Models in this Series There […]
Used on Jetson
Introduction The autofocus camera is an advanced IMX219 camera module for Jetson Nano/Xavier NX board. It helps to focus the object in close range from 5cm~30cm, within this range the standard fixed focus camera can not get sharp focus and the image looks burry. All the focus procedure is controlled by the software without manually […]
