Arducam 5MP Synchronized Stereo Camera Bundle Kit for Jetson Nano
Arducam OV9650 1.3 Mega Pixels Camera module
Arducam 8MP 1080P 5-50mm Varifocal USB2.0 Camera Module, 4K Sony CMOS IMX179 UVC USB2.0 Webcam Board with 6.56ft/2m Cable for Windows, Linux, Android and Mac OS
UB0213
Discontinued, please check the 12MP version SKU:B0288
  • More than HD: This camera adopts 8MP IMX179 sensor for sharp image and accurate color reproduction
  • Multiple Adjustable: Rotate the zoom ring, focus ring and aperture ring to get clear image in different focus distance.
  • High Frame Rates: MJPG 15fps@3264 x 2448; 30fps@1920 x 1080; YUY2 30fps@640 x 480
  • Plug&Play: UVC-compliant, just connect the camera to PC computer, laptop, Android device or Raspberry Pi with the USB cable without extra drivers to be installed.
  • Applications: Widely used for the video surveillance system, live streaming, record lesson and conference, and other vision applications.
$74.99
Arducam has been a professional designer and manufacturer of SPI, MIPI, DVP and USB cameras since 2012. We also offer customized turnkey design and manufacturing solution services for customers who want their products to be unique.
Arducam UB0213 is a new member of the Arducam's USB camera family. It's an 8MP, based on the 1/3.2" Sony IMX179 image sensor, UVC compliant, 5-50mm varifocal USB 2.0 camera with the metal shell.
Applications:
  • Video conference
  • Live streaming
  • Record lesson and conference
Features & Specs
  • Sensor: 1/3.2” IMX179
  • Resolution: 8MP 1920 x 1080
  • Data Format: H.264/MJPG/YUY2
  • Frame Rate: MJPG 15fps@3264 x 2448; 30fps@1920 x 1080; YUY2 30fps@640 x 480
  • Field of View (FOV): 58°-6.8°
  • Lens Mount: CS
  • Focal Length: 5-50mm
  • Auto Controlled Features: Saturation, Contrast, Acutance, White balance, Exposure.
  • System Compatibility: Windows, Linux, Mac, and Android with UVC
Power
  • Power Supply: USB powered 5V
  • Working Current: MAX 500mA
Physical
  • Operating Temp.: -4°F~158°F (-20°C~+70°C).
  • Dimension: 50mmx50mmx100mm
  • Cable Length: default 6.56ft (2M)
  • 1 × 8MP IMX179 5-50mm varifocal USB 2.0 camera with full metal shell
  • 1 × 6.56ft (2M) USB 2.0 cable
