[High Resolution] 12MP, Max resolution: 4608 × 2592
[Wide Angle Fixed Focus]: 120 °(DFOV) Wide Angle Fixed Focus Lens, integral IR-cut filter. With Fixed Focus Lens, you can get a more stable and quickly generated image.
A 12MP USB camera module with HDR support and a 120 °(DFOV) Wide Angle fixed-focus lens, designed for high-quality imaging up to 4608×2592 resolution. Its integrated 650nm IR-cut filter ensures accurate color performance. With plug-and-play compatibility on Windows, Linux, Android, and macOS—no driver required—the A708 is a reliable UVC solution for applications demanding clarity, durability, and wide dynamic range.What’s more, if off-the-shelf solutions don't meet your needs, Arducam offers end-to-end custom camera design services to help you turn your ideas into real products. From early concept to mass production, we work closely with you to tailor an imaging solution to meet your unique technical requirements and product goals.
Robotics
Precision Agriculture
Medical and Scientific Research
Document Scanning and Archiving
Broadcast and Media Production
[Plug-and-Play]: This 12MP camera module offers hassle-free plug-and-play operation across Windows, Linux, Android, and macOS platforms. No additional drivers or software are required—simply connect via USB and start capturing high-quality images instantly.
[HDR Support]: Equipped with High Dynamic Range (HDR) technology, the camera captures well-balanced images that retain detail in both bright and shadowed areas, delivering superior image quality in challenging lighting environments.
[High Resolution]: Featuring a 12MP sensor, the camera produces sharp still images with a maximum resolution of 4608 × 2592 pixels, ensuring clear and detailed visuals suitable for demanding applications.
[Wide-Angle Fixed Focus]: The module is fitted with a high-quality 120 °(DFOV) wide-angle fixed-focus lens designed for consistent sharpness at a set focal distance. An integrated 650nm IR-cut filter enhances color accuracy by blocking infrared light, making it ideal for true-to-life color reproduction.
