Global Shutter USB2 UVC Camera, Ultra High FPS, VGA Monochrome, Arducam ezBOX GS
Arducam A708, 120°(DFOV) Wide-Angle Fixed Focus, 12MP HDR USB2 UVC Camera Module
Arducam 12MP 4K@25fps USB2.0 UVC Wide Angle Camera Module for Windows, Linux, and Android
B0621
  • [4K Ultra HD] Powered by a 12MP high-resolution image sensor, delivering a maximum resolution of 4032(H)×3040(V).
  • [Enhanced Image Quality] Features an upgraded core controller for significantly improved clarity and overall image performance.
  • [150° Ultra Wide-Angle] Equipped with a 150° DFOV M12 wide-angle lens, ideal for landscape photography and large-scene capture.
  • [Wide Compatibility] UVC protocol compliant, supporting Windows, Linux, Android, and embedded systems out of the box.
  • [Plug & Play] UVC-compliant, driver-free, and ready to use immediately after connection.
$49.99
The Arducam 12MP 4K@25fps USB2.0 UVC Wide Angle Camera Module delivers high-resolution imaging with exceptional ease of use. Built around a 12MP high-performance image sensor, it supports clear 4K video at 25fps and a maximum resolution of 4032×3040, ensuring sharp, detailed visuals for a wide range of applications. Featuring an upgraded core controller and a 150° DFOV M12 wide-angle lens, this camera module provides improved image quality and expanded field of view, ideal for large-scene capture, landscape recording, and wide-view projects. Compliant with the standard UVC protocol, it offers full plug-and-play functionality with no drivers required, and is widely compatible with Windows, Linux, and Android systems. Designed for reliability and simplicity, it is a versatile solution for embedded vision, monitoring, creative imaging, and everyday camera applications.
  • 3D Scanner
  • VR Camera
  • Lightburn Laser Engraver Machine
  • Surveillance
  • Video System
  • 4K Ultra HD High Resolution Powered by a high-quality 12MP image sensor, this camera module supports a maximum resolution of 4032(H)×3040(V) and smooth 4K video at 25fps, delivering sharp, detailed, and high-definition images for professional and daily imaging applications.
  • Enhanced Image Quality Adopting an upgraded core controller solution, the camera significantly improves overall image performance with better clarity, color accuracy, and stability, ensuring consistent and reliable imaging even in varied lighting conditions.
  • 150° Ultra Wide-Angle Lens Equipped with a 150° DFOV M12 wide-angle lens, this module captures a much broader field of view compared to standard lenses, making it highly suitable for landscape photography, large-area monitoring, scene capture, and wide-view applications.
  • Wide System Compatibility Fully compliant with the standard UVC protocol, the camera supports a wide range of systems including Windows, Linux, Android, and embedded platforms, offering great flexibility for different devices and development environments.
  • Easy Plug & Play Operation Designed for hassle-free use, this UVC-compliant camera supports true plug-and-play functionality with no additional drivers or complex setup required, allowing users to start capturing images and videos right after connection.
Image Sensor SONY 12MP Image Sensor
Max Still Resolution 4032(H)x3040(V)=12.3MP
Optical Size 1/2.3''
Output Format MJPG
Pixel Size 1.55 µm x 1.55µm
Sensor Active Area 4032(H) x 3040(V)
Frame Rate(MJPG) 4032x3040@10fps, 3840x2160@25fps; 2592x1944@25fps, 2056x1520@30fps; 1920x1080@30fps, 1600x1200@30fps; 1280x720@30fps, 640x480@30fps;
FOV 150°(D)x120°(H)x90°(V)
Lens Mount M12*P0.5
F.NO F2.8±5%
E.F.L 2.87±5%mm
Default Focus Range 0.5m-INF
Distortion -63.41%
Weight 5g
Interface USB 2.0 Device
Connector B4B-ZR JST
Supported Cable Length 1m by default, 3m USB Cable Supported
Supported OS Windows, Linux, Android
UVC Controls Brightness, Contrast, Sharpness, Backlight Compensation, Gain, Exposure(Auto/Manual).
Operating Voltage 5V
Power Consumption 1.3W
Camera Board Size 32mmX32mmX1.6mm
Overall Weight (Net) 150g
Overall Size 38.6x44.83x13.78 (exclude the Lens)
Certifications RoHS, FCC
  • 1 x Arducam 12MP Wide Angle USB2 UVC Camera Module
  • This module supports customized resolution, frame rate, and ROI.
  • This module supports a minimum exposure time of 100µs under the current UVC protocol. For even lower exposure times, please contact Arducam for customization.
