Arducam 12MP A708: 12MP USB camera module designed for high-quality imaging up to 4608×2592 resolution. With plug-and-play compatibility on Windows, Linux, Android, and macOS—no driver required—the A708 is a reliable UVC solution for applications demanding clarity, durability, and wide dynamic range.
Check upgraded version(B030401) with additional HDR support and autofocus lens which integrated with 650nm IR-cut filter ensures accurate color performance, while the sturdy metal housing provides effective heat dissipation and protection.
[Plug-and-Play]
This 12MP camera module offers hassle-free plug-and-play operation across Windows, Linux, Android, and macOS platforms. No additional drivers or software are required—simply connect via USB and start capturing high-quality images instantly.
[AI Resolution]
Multiple preset AI image resolution. You can directly train and deploy your AI model without additional image cropping(B030401(Upgraded)).
[High Resolution]
Featuring a 12MP sensor, the camera produces sharp still images with a maximum resolution of 4608 × 2592 pixels, ensuring clear and detailed visuals suitable for demanding applications.
[Upgraded Option]
Check B030401, which is equipped with High Dynamic Range (HDR) technology, Excellent Autofocus Lens, and Metal Case. Same price, better performance.
| General Sepcs | B030401(Upgraded) | B0304-1(Standard) |
| Image Sensor | ||
| Still Resolution | 12MP | 12MP |
| Color Filter Type | Color | Color |
| Shutter Type | Rolling | Rolling |
| Optical Size | 1/2.43" | 1/2.43" |
| Output Format | MJPG/YUY2 | MJPG |
| Pixel Size | 1.4µm x 1.4µm | 1.4um x 1.4um |
| Sensor Active Area | 4608(H)x2592(V) | 4608(H)x2592(V) |
| Frame Rate(MJPG) | 4608x2592@15fps, 3840x2160@25fps; 3264x2448@25fps, 2592x1944@30fps; 1920x1080@30fps,1280x720@30fps; 640x480@30fps; |
4608x2592@10fps, 2304x1296@30fps; 1920x1080@30fps, 1600x1200@30fps;1280x720@30fps; |
| Frame Rate(AI Resolution(YUV)) | 640x480@30fps, 320x240@30fps; 320x320@30fps, 128x128@30fps; 96x96@30fps; |
| Lens | ||
| IR Sensitivity | Integral 650nm IR Filter, visible light only | Integral 650nm IR Filter, visible light only |
| Focus Type | Autofocus | Fixed Focus |
| FOV | 75°(D)×61°(H)×50°(V) | 75°(D)x66°(H)x41°(V) |
| Lens Mount | Stock Lens | Stock Lens |
| F.NO | F1.8 | F1.8 |
| E.F.L | 3.95mm | 4.74mm |
| Default Focus Range | 10cm-∞ | 150cm-∞ |
| USB Interface | ||
| Interface | USB 2.0 Device | USB 2.0 Device |
| Connector | B4B-ZR JST | B4B-ZR JST |
| UVC Compliant | No additional drivers required | No additional drivers required |
| Electrical and Mechanical | ||
| Operating Voltage | 5V | 5V |
| Operating Temp. | 32°F-158°F (0°C to 70°C) | 32°F-158°F (0°C to 70°C) |
| Power Consumption | Max: 1.75W | Max: 1.5W |
| Camera Board Size | 32mm x 32mm x 1.6mm | 24mm x 25mm |
| Functionality and Compatibility | ||
| HDR Support | YES | NO |
| Enclosure | with Metal Enclosure | without Enclosure |
| Supported OS | Windows, Linux, MacOS | Windows, Linux, MacOS |
| Recommend Sample Application | Amcap for Windows, qv4l2 for Linux | Amcap for Windows, qv4l2 for Linux |
| UVC Controls | Brightness, Contrast, Saturation, White Balance (Auto/Manual), Lowlight Compensation, Gain, Focus (Auto/Manual), Exposure (Manual/Auto) | Brightness, Contrast, Saturation, White Balance (Auto/Manual), Gain, Focus (Auto/Manual), Exposure (Manual/Auto) |
