Arducam A708, 120°(DFOV) Wide-Angle Fixed Focus, 12MP HDR USB2 UVC Camera Module
Arducam True Day & Night Vision USB2 UVC Camera with IP65 Waterproof Housing
Arducam 1080P Ultra Low Light 100 Degree Wide Angle USB2 UVC Camera Module
B0635
  • [Ultra Low Light] Boosts low-light sensitivity with Nyxel® and PureCel®Plus technologies for crisp, low-noise nighttime imaging.
  • [1080P Full HD] Captures crisp and detailed high-definition video at smooth frame rates for professional applications.
  • [100° Wide Angle] Features a 100-degree diagonal field of view to capture more content.
  • [Plug-and-Play] Driverless UVC-compliant USB2 interface ensures quick and effortless setup across multiple platforms.
  • [Rich ISP Controls] Offers versatile manual and auto adjustments for brightness, contrast, white balance, and exposure.
  • [OEM/ODM] Customization options available.
$47.99
The Arducam 1080P Ultra Low Light USB2 Camera Module is a high-performance imaging solution engineered for challenging environments. Integrating Nyxel® near-infrared and PureCel®Plus pixel technologies, this module captures crisp, noise-free Full HD video even in the darkness. With its generous 100° wide-angle view and driverless UVC plug-and-play convenience, it integrates seamlessly into various setups. Whether you need precise auto-adjustments or manual fine-tuning, its comprehensive ISP controls give you complete command over every visual detail, making it a reliable choice for advanced vision systems.
  • Nighttime Security and Surveillance: Ideal for monitoring low-illumination areas without requiring heavy external lighting.
  • Industrial Machine Vision: Perfect for automated inspection lines and robotic guidance in variable lighting environments.
  • Smart Kiosks and ATMs: Enables reliable facial recognition and user interaction in dimly lit indoor or outdoor settings.
  • Medical Imaging Devices: Suitable for specialized medical equipment requiring high-sensitivity and detailed color reproduction.
  • [Ultra Low Light Excellence] Enhanced by Nyxel® near-infrared and PureCel®Plus technologies, this camera module excels in dim environments, capturing bright, color-accurate, and ultra-low-noise images under the most challenging lighting conditions.
  • [1080P HD Definition] Stream and record crystal-clear Full HD video at smooth frame rates, ensuring that every crucial detail is preserved for high-accuracy analysis or high-quality video streaming.
  • [100° Wide Angle View] Equipped with a finely calibrated 100-degree diagonal field of view lens, it maximizes visual coverage, making it ideal for monitoring expansive areas without unacceptable distortion.
  • [Seamless Plug-and-Play] Fully compliant with UVC standards, this USB2 camera module requires no extra drivers, offering hassle-free compatibility with Windows, Linux, and Android systems out of the box.
  • [Advanced ISP Controls] The onboard Image Signal Processor allows users to fine-tune every detail through manual or automatic adjustments, including brightness, contrast, saturation, white balance, exposure, and gain.
Max Still Resolution 2 Megapixels
Optical Size 1/2.8″
Output Format MJPG/YUV/H.264
Pixel Size 2.9 µm x 2.9 µm
Sensor Active Area 1920(H) x 1080(V)
Frame Rate(MJPG/H.264) 1920x1080@30FPS, 1280x720@30FPS; 640x480@30FPS, 320x240@30FPS;
Frame Rate(YUV) 640x480@30FPS, 320x240@30FPS; 320x320@30FPS, 128x128@30FPS; 96x96@30FPS;
FOV 102°(D)×88°(H)×47°(V)
Lens Mount M12-S
F.NO F1.0
E.F.L 3.9mm
Default Focus Distance 300cm~INF
Distrotion TV Distortion: -10.4%; F-θ Distortion: -32.0%
USB Features
Interface USB 2.0 Device
Connector B4B-ZR JST
Supported OS Windows, Linux, Android
UVC Controls Brightness, Contrast, Gamma, Gain, Sharpness, Backlight Compensation, Lowlight Compensation, Exposure (Manual/Auto)
Power Consumption Max: 1W
Camera Board Size 38mmX38mmX1.6mm
Overall Weight (Net) 18g
Certification RoHS
  • 1 x Arducam 1080P Wide-Angle Ultra Low Light USB2 UVC Camera Module
