[Discontinued] Arducam Pan Tilt Camera for Raspberry Pi, 2 DOF Platform with 5MP 1080P Camera Board with PTZ Control Board
[Discontinued] 1080P Low Light Low Distortion USB Camera Module with Microphone, 2MP IMX323 Mini Webcam
[Discontinued] Arducam 8MP Synchronized Stereo Camera Bundle Kit for Jetson Nano
B0217J8
$109.99
As part of Project Jetvariety, which allows any camera modules to be connected to the high-speed CSI-2 connector on the Jetson Nano. Arducam released this Synchronized Stereo Camera Bundle Kit for Jetson Nano, which allows customers to connect two 8MP IMX219 cameras to a single Jetson Nano board, and takes images or video at the same time, even more important they are fully synchronized. The highlight of this kit is that it incorporates Arducam proprietary ArduChip solution, and extends the usage of the single Jetson Nano camera port, it cheats the board as if only one camera connected.
Key Specifications:
  • Support 1, 2  lane MIPI cameras input up-to 1Gbps/lane
  • Support 2 lane MIPI output
  • Support digital pan in half resolution combine, programmable pan speed control
  • HAT size: 65 x 56 mm
  • Focus distance: 200mm ~ infinity
Driver Features
  • Support Ardcuam Stereo Camera HAT
  • Support OfficialIMX219 driver, Video Nodes, and Controls (Exposure, Gain and depending on camera parameters)
  • Single Line Driver Installation Command
  • OpenCV Friendly and Provides Source Code Demonstration
  • Stereo Vision
  • 360° Camera
  • Advanced Surveillance Camera
  • Enhanced Vision Goggles
Camarray – Arducam 8MP IMX219 Synchronized Stereo Camera Bundle Kit
Introduction ​This Arducam 8MP Synchronized Stereo Camera Bundle Kit is capable of running two 8MP IMX219 Camera Modules simultaneously through a single MIPI CSI-2 camera slot connection on Jetson Nano/Xavier NX. The stereo camera HAT is enabled by ArduChip to disguise the dual-camera connection as a single camera to be accepted by the single-board computers. […]
arducam jetson nano camera general purpose solution blog thumbnail 215 187
Introducing Project Jetvariety – Increase the Jetson Nano Camera Variety Today we are proud to introduce the Project Jetvariety (short for Jetson variety), which aims to quickly increase the variety of Jetson Nano cameras with our proprietary general-purpose camera solution. The Jetson Nano and Xavier NX only have official driver support of the Raspberry Pi […]
16 comments
