[Discontinued] Arducam 1080P Low Light WDR USB Camera Module with Metal Case and Tripod, 2MP 1/2.8
[Discontinued] Arducam 1080P Low Light WDR USB Camera Module with Metal Case and Tripod, 2MP 1/2.8" CMOS IMX291 160 Degree Ultra Wide Angle Mini UVC Webcam Board with Microphone, 3.3ft/1m Cable for Windows Linux Mac OS
[Discontinued] Arducam OV9281 1MP Mono Global Shutter Camera with 130deg 850nm Only M12 Mount for Raspberry Pi
[Discontinued] Arducam 2MP*2 Stereo Camera for Raspberry Pi, Nvidia Jetson Nano/Xavier NX, Dual OV2311 Monochrome Global Shutter Camera Module
B0264
Check alternative solutions B0265R, B0265N, B0267.
  • Wide Compatibility: Compatible with Raspberry Pi and Jetson Nano/Xavier NX
  • More Reliable: MIPI CSI connector, which outperforms better integrity, higher throughput keeps reliability even in the vibration environment
  • Complete Synchronization: The frames of dual cameras is synchronized in hardware level
  • Mono Global Shutter: Excellent detail and sensitivity allow it to get real-time, higher accuracy and frame rates
  • More Applications: Depth sensing, 3d mapping, VR/AR vision, multi position photo, etc.
$149.99
Stereo vision systems give the robots depth perception skills, which make artificial machines and systems develop an understanding of their environment by estimating the relative distance of objects in their vision from many visual cues. Hence, stereo vision are used in many areas of robotics, such as self-driving cars, drones for rescue missions, robots for remote surgery.
Arducam released this Stereo Camera MIPI Module Series for Raspberry Pi and Jetson Nano/Xavier NX. They directly connect to the MIPI CSI-2 connectors of the motherboards, and run with a V4L2 camera driver on those platforms. They offer better flexibility to be integrated into your own hardware design or run with your own algorithm on embedded systems for applications like depth sensing, 3d mapping, SLAM, etc.
This Arducam 2MP Stereo Camera MIPI Module is a stereo camera module with two synchronized monochrome global shutter OV2311 image sensors (2x2MP). The monochrome sensor's capable of excellent detail and sensitivity allow it to get higher accuracy and frame rates in extracting depth information.
  • Depth sensing
  • 3d mapping
  • SLAM
  • 360 camera
  • VR / AR application, etc.
  • Complete Synchronization(The frames of two cameras are synchronized at the hardware level, extra synchronization scheme by time stamping or so does not need to be considered).
  • Mono Global Shutter: Shoot high-speed moving objects in crisp sharp images.
  • The ISP processing function is supported on the Raspberry Pi platform, and the max frame rate is: 50fps@3200×1300
  • The ISP processing function is not supported on the Nvidia Jetson platform, and the max frame rate is: 50fps@3200×1300
Support Platform Raspberry Pi  and Jetson Nano
Output/CSI-2 Speed x1 CSI-2 2-lane Output Port/1.0 Gbps/Lane
ISP Support Supported on Raspberry Pi, Not supported on Nvidia Jetson
External Trigger Support
Aggregate mode Side-by-Side
Frame Rate(On Raspberry Pi) Raw8/Raw10: 3200x1300@40fps, 3200x1080@80fps, 2560x720@80fps
Frame Rate(On Nvidia Jetson) Raw8/Raw10: 3200x1300@40fps, 3200x1080@80fps, 2560x720@80fps
Image Sensor Monochrome Global Shutter OV2311
Pixel Size 3 μm x 3 μm
Active Array Size 1600 x 1300
Optical Size 1/2.9 inch
Focusing Range 30mm ~ infinite
IR Sensitive No IR filter, sensitive to IR
Board Size 105(L) x 24(W) x 20.1(H) mm
Optical Format 1/2.7”
Distortion <1%
Effective Focal Length 2.8mm
FOV on 1/4” RPi Camera 83° (H)
F/NO 2.8
Lens Mount M12
Default Lens Low distortion M12 lens (Part Number: M27280M07S)
  • 1 x Arducam 2MP OV2311 stereo MIPI camera module with low distortion M12 Mount Lens
  • 1 x 150mm 15pin 1.0mm pitch FPC cable
  • 1 x 150mm 15pin 1.0mm to 22pin 0.5mm pitch FPC cable
  • Raspberry Pi & Jetson Nano/Xavier NX boards, acrylic case, and tripod are not included in the package.
  • This camera relies on kernel drivers to work - one kernel version, one camera driver. Up or downgrading your OS leads to a kernel bump, and you may need to re-install a matching driver.
  • The driver of the kit is mainly developed based on the Raspberry Pi/Nvidia Jetson official board, and there is no guarantee that the third-party board can be used (due to the different allocation of hardware resources, it is not compatible with the driver)
  • The I2C signal and clock of each camera are fully synchronized. It is unavailable to capture the same frame of images at different exposure times/gains for each camera.
  • Our main business is to assist customers in acquiring data from binocular cameras. Due to the extensive backend processing involved in depth vision, we regret that we cannot provide comprehensive operational guidance to cover all requirements. If you have relevant needs, you may refer to open-source demos for binocular cameras, such as those offered by NVIDIA.
  • The camera kit does not have an onboard ISP, using the ISP function is platform-dependent. (On the Raspberry Pi platform, you can use the ISP processing of images. On the Jetson platform, image capture tools and applications conforming to the V4L2 standard framework are supported, but ISP processing of images is not supported).
3D drawing.step
Used on Pi:
Camarray – Arducam 2MP*2 Stereo Camera MIPI Module
Introduction This Arducam 2MP*2 Stereo Camera MIPI Module is a stereo camera module with two synchronized monochrome global shutter OV2311 image sensors (2×2MP). It directly connects to the MIPI CSI-2 connectors of Raspberry Pi and Jetson Nano, and runs with a V4L2 camera driver on those platforms. It offers better flexibility to be integrated into […]
Used on Jetson Nano:
Arducam Blog Thumbnail camarray release
13 comments
Camarray Stereo Camera Tutorial for ROS:
Arducam Camarray Solution Showcase:
